Want To Make Under Cabinet Lights Right - Electrical - DIY Chatroom Home Improvement Forum
Old 06-23-2011, 05:59 PM   #1
Rewards Points: 16
Want to make under cabinet lights right
Greetings,
I installed under cabinet lights that I am sure are not to code... I would like to make it right. My first question, is it per code to contain an outlet and a switch in a duplex box?
Second question is, I've wired the switch into the GFI protected outlet beside it. I know you can't connect lights to this, but I've heard this switch can can control an outlet strip that the under cabinet lights plug into. Is that correct?
Thanks!
Dshow is offline   Reply With Quote
Old 06-23-2011, 06:30 PM   #2
Licensed electrician
Rewards Points: 1,778
You can have the switch and the receptacle in the same box. You cannot however have the undercabinet lighting on the small appliance receptacle circuit. This is the one that you tapped into to get your power.
Old 06-23-2011, 07:30 PM   #3
Rewards Points: 16
Thanks Jim. Can I run the switch to control an outlet strip right below the cabinets (approx 8" up)?
Old 06-23-2011, 07:49 PM   #4
Rewards Points: 101
Jim, does this requirement apply also to cabinets not in the kitchen? We are installing cabinets at our entry way (think mud room even though it's not a separate room). And I'm thinking about wiring receptacles and a switch to the in-cabinet lights this way.
mudworm is offline   Reply With Quote
Lights Make Clunking noise when Turned on. mkaltenbach Electrical 9 11-29-2010 09:32 PM
Help with Two Switches & Two Lights simplyphp Electrical 36 11-25-2010 02:47 PM
Kitchen sink not centered. gmhut Plumbing 5 06-01-2010 11:44 AM
Wiring up an outside set of motion sensing lights airdaleairdale Electrical 1 06-11-2009 08:35 PM
German Bathroom Cabinet with Lights jhassall@dornbracht.co.uk Electrical 2 01-06-2009 12:58 PM
