#1 |
want to make ceiling light fixture into plug-in lamp
A total novice question -- I have a 20 year old fluorescent ceiling light fixture, which I would like to convert into a plug-in lamp (I'm a gardener and am looking for an inexpensive way to set up a grow station for seeds/plants). I'm looking at the fixture, and it has 8 wires that connect to the Ballast -- two red and two blue that run to the two lamps/bulbs, two yellow that run to the other end of the lamps/bulbs, and a white and a black that obviously connect to the power source. There is no ground wire, though the ground wire from the house wiring had connected to a screw on the fixture. The fixture is 120 volts, 60 Hz and houses two 40 watt flourescent bulbs.
The question is -- is converting this fixture into a plug in lamp as simple as taking a heavy gague cord+plug, and connecting white to white and black to black? Are there any safety concerns with doing this? Clearly, I don't want to burn my house down just to save a couple of bucks. On the other hand, it would be a great way to put an unused fixture back into productivity. Thanks in advance |
#2 |
Mechanical Contractor
Use sj cord with a stress relief plug attached through the knockout hole that the power entered and attach the ground wire from the cord to the metal housing with a small bolt and nut. And yeah black to black and white to white.
#3 |
Remodeler
Don't forget to use wire nuts on the connections and tape them also. Be sure the cord is protected where it exits the lamp housing and run the cord's ground to the metal chassis of the fixture.
Minichillo's Construction I will never leave you hanging! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#4 |
Why tape wire nuts? If they are installed properly that is kind of a waste of time and tape.
#5 |
Remodeler
I see it as an added form of safety. I have seen wirenuts come loose from vibration, hot - cold cycles. The cost of tape is nothing compared to the cost of a fire.
#6 |
Home Improvement Guy
want to make ceiling light fixture into plug-in lamp |
#7 |
Electrical Contractor
A properly installed wirenut does not need taping nor does doing so add any safety. IMO and the manufacturers opinion. An improperly installed wirenut also does not benefit from taping you are just hiding the improper install under tape.
#8 |
so is there no need to carry the ground wire of a hardwired lamp to a 3 prong plug then? i ask b/c i would like to change a pendant lamp that i purchased to a plug in type.
#9 | |
Floor Sweeper
want to make ceiling light fixture into plug-in lampQuote:
If the lighting fixture has a ground screw or provisions for grounding, you are required to use a 3 wire cord with a three prong plug. The green wire of the cord goes to the ground screw. |
| Display Modes | |
| Ceiling fan light fixture doesn't work | c4hfam | Electrical | 9 | 03-05-2011 02:01 PM |
| Part of a ceiling fan light fixture needs help...please | g5729 | Electrical | 1 | 06-17-2007 07:22 AM |
| ANOTHER ceiling fan light fixture doesn't work | bandguy | Electrical | 8 | 06-13-2007 09:40 AM |
| converting hanging light fixture to plug | dukeswalker | Electrical | 2 | 09-18-2006 10:03 PM |
| Installing a ceiling light fixture? | DK75 | Electrical | 7 | 02-27-2006 09:10 AM |
