Want To Convert 4-pin Base Recessed Lighting To LED (gx24) - Electrical - DIY Chatroom Home Improvement Forum
Old 02-10-2013, 12:02 PM   #1
Want to convert 4-pin base recessed lighting to LED (gx24)
The lights are in my kitchen and living area and all have a 4-pin base. I would like to convert to LED. Big Orange has these: http://www.homedepot.com/webapp/wcs/...3#.URfgDlqLyd8
I bought one and the light seems to be good, but how should I go about installing it? can I get some type of converter? I asked at big orange and the guy assured me they don't have any adaptors.
Am I better off changing out the whole socket? I would prefer not to do that? Should I look for some LED light bulbs with 4-pin bases and just settle on that?
I'm open to ideas and appreciate all the help in advance. Thanks!
uvince is offline   Reply With Quote
Old 02-10-2013, 12:36 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
By 4 pin base, I'm assuming your cans take some sort of fluorescent twin tube type lamp. If I'm correct, you will not be able to convert these cans to those LED trims. You will need to change out the can in order to use them.
Tags
led , retrofit
Can I convert a screw base to a 2 or 4 pin base? DeniB Electrical 3 02-01-2012 01:52 PM
high pitched noise recessed lighting pbrzez Electrical 2 03-30-2011 11:23 AM
Recessed Lighting Layout - HELP foxwoods321 Electrical 12 02-24-2011 09:32 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 12:25 PM
Recessed Lighting - Quality Question. 811Gibbon Electrical 8 01-24-2009 09:47 PM
