Want To Change A Single 240 Volt Circuit With Only One Outlet, To A 120 Volt Circuit With A Standard 120 Volt Outlet. - Electrical - DIY Chatroom Home Improvement Forum
Old 11-09-2010, 01:49 PM   #1
Want to change a single 240 volt circuit with only one outlet, to a 120 volt circuit with a standard 120 volt outlet.
Want to change a circuit that provided one outlet for a dryer and tested at 240 volts... to a standard 120 volt circuit (the circuit is only one wire run from breaker box to outlet).
The one wire run (is an older shielded two wire 10 gauge) runs from breaker box - where the black is connected to a 30 amp breaker and the white is connected to a 30 amp breaker (both breaker switches are clamped together so the breakers on/off together).
There is a bare copper wire that now attaches to the 240 outlet and then to a bare copper wire run that goes in between all the outlets (both 240 and 120 volt) and then into a bare wire that runs into the circuit box. The whole house (built 1957) is wired this way... 12/2 wire with bare copper externally connecting all the circuits to the breaker ground.
covenant is offline   Reply With Quote
Old 11-09-2010, 02:18 PM   #2
Where is this outlet located?
lordlondis is offline   Reply With Quote
Old 11-09-2010, 02:51 PM   #3
Only outlet for this circuit is located on wall in garage... the same location that I am building a recessed wall for kitchen refrigerator. The changed 120 volt circuit will be wired for the refigerator since the wire will drop perfectly down to outlet height within new wall. --- There is only this one outlet on the entire line (circuit).
Old 11-09-2010, 03:10 PM   #4
MORE - Asking for feedback before I do what I assume is correct: Take off white wire on circuit breaker, attach to common bar in breaker box. Use existing 30 amp circuit breaker (with black wire) to downgrade to a 120 volt circuit for the outlet - will test wiring before installation of outlet...
Old 11-09-2010, 03:37 PM   #5
Rewards Points: 330
no on the 30 amp.change to single pole 20 amp.label #10 black wire in panel for 20 amp only.
oleguy74 is offline   Reply With Quote
Old 11-09-2010, 03:38 PM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Replace the 30 amp breaker with a 20 amp breaker!
Old 11-09-2010, 03:44 PM   #7
OK - thanks... will change breaker to 20 amp single pole and mark it's 10 guage wire with "20 AMP ONLY"...
Old 11-09-2010, 06:07 PM   #8
Also if you are only using it for the fridge put in a 20 amp single receptacle. if you are going to use it as general purpose it needs to be a gfci outlet as per code. You are also going to want to splice #12 thhn to the #10 wire to make it easier to connect to the outlet.
220 volt circuit GFCI Captflx Electrical 16 09-29-2011 06:53 AM
240 volt circuit and 120 volt circuit to shed fortop Electrical 27 06-26-2010 11:37 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
