Want A Ceiling Fan, But... - Electrical - DIY Chatroom Home Improvement Forum
Old 07-06-2011, 03:00 AM   #1
Rewards Points: 39
Want a ceiling fan, but...
My bedroom ceiling has no existing fixture/wiring to put one up there. There is a closet light in the bedroom I was wondering if I could tap into to get power to the fan. Does it violate any codes? And speaking of code, is there any particular way to run the new wiring? I know it would need to be fastened to the joists somehow, but would it be on top of the joists or sides??? I don't plan to have a light switch connected to this fan on the account I'd have more work to do. I called a few handyman/electricians, but they want $200 to $400 to do what seems like a simple task.
I used a stud finder to locate the joists over my bedroom. They do appear to be 1 1/2" thick and 16" apart from each other. I can't get into the attic right now because I don't have a ladder tall enough. But it is possible.
Here's some pictures of my bedroom ceiling and closet.
http://img835.imageshack.us/img835/7639/brjd.jpg
http://img837.imageshack.us/img837/9017/brce.jpg
Sliding Man is offline   Reply With Quote
Old 07-06-2011, 04:04 AM   #2
Licensed electrician
Rewards Points: 1,768
You might be in luck if you have a constant source of power in your light junction box. I suspect you do since you have a pull chain to turn the light on and off. All you would need to do is run a properly sized cable between the existing box and the new fan rated support box. I would secure to the sides of the joist so someone does not step on the cable.
BTW, those open bulb fixtures are no longer allowed in closets due to being a fire hazard. Stuff can be piled up or fall onto the bulb and ignite.
Sliding Man (07-06-2011)
Old 07-06-2011, 10:11 PM   #3
Rewards Points: 39
I'll find a different type of fixture for the closet. There are so many of these in the house.
Old 07-12-2011, 11:28 PM   #4
Rewards Points: 39
Flaming attic of flame! But I managed to do it.
http://img39.imageshack.us/img39/7863/donekp.jpg
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Ceiling for cistern under front porch T-Bar Building & Construction 3 02-08-2011 12:31 PM
Raise ceiling/Tray Ceiling. Is it even possible? Bombcru Building & Construction 10 02-08-2011 01:01 AM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 05:04 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
