Wanna Guess Problem? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-20-2014, 02:50 PM   #1
Rewards Points: 455
Ok. Here was call. When they opened the oven door (directly below micro) the micro came on. When they closed the oven door the micro went off. The micro and stove are 2 seperate stand alone units
Any guesses ?
Cletis is offline   Reply With Quote
Old 07-20-2014, 03:22 PM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Originally Posted by Cletis
Ok. Here was call. When they opened the oven door (directly below micro) the micro came on. When they closed the oven door the micro went off. The micro and stove are 2 seperate stand alone units Any guesses ?
its a problem with the feeder.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 07-20-2014, 03:27 PM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,820
Not really realistic, or I can't exactly explain how it would happen......
but someone somehow X wired/tapped the oven 120 circuit into the micro... when the oven light went on the micro went on... and visa-versa.
Basically..... NFI... but sure curious.
Best
MTN REMODEL LLC is offline   Reply With Quote
Old 07-20-2014, 04:10 PM   #4
Rewards Points: 774
Cletis wired the house.
Know A Little is offline   Reply With Quote
The Following User Says Thank You to Know A Little For This Useful Post:
MTN REMODEL LLC (07-20-2014)
Old 07-20-2014, 04:11 PM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 1,820
Troll in the house?
Old 07-20-2014, 04:38 PM   #6
dmxtothemax's Avatar
Rewards Points: 5,354
The ovens backfeeding the microwave !
You open the oven door, oven light turns on,
this provides a current path for the microwave.
They must be on opposite hots,
And one is down !
Even Cletis should know this one !
dmxtothemax is offline   Reply With Quote
Old 07-20-2014, 06:47 PM   #7
And one is down !
Still thinking it over...... but how would the oven light back feed the other leg?
Oven being on (not just the light), I'd buy that someone tapped a 120 leg off the oven to feed the 120 micro.
Old 07-20-2014, 07:21 PM   #8
Rewards Points: 3,256
The oven door hinge/mechanism was hitting or chewing up the microwave circuit which had a bad connection.
zappa is offline   Reply With Quote
Old 07-20-2014, 07:45 PM   #9
When the guy bent over to open the oven door, his head was hitting the micro on switch.....
Common.... we're curious and impatient.... but these are fun puzzels.
Best
Old 07-20-2014, 08:44 PM   #10
Rewards Points: 455
Some good guesses there. I think dmx was the closest with the limited info I provided. HEre is whole story
Yes. It was a service call and yes I fixed it. Here is what I found. It must have been an old dedicated 120V outlet that was reused for the microwave. The only thing was, the new one was a 220V one. As far as the stove below, same thing. An old 6/2 seu. The new stove needed a 4 wire. So, someone ran a jumper (4th wire from stove and micro to closest gfci outlet on counter. Here is thing, they ran it off the load side of gfci, so when door opened on stove it let the neutral current flow. When it was switched back to line side everything worked fine.
Old 07-20-2014, 09:00 PM   #11
Cletis... God love ya.... but your explanation makes no sense to me.
Does it to others?
I'll go back and read it again.
I have no idea as to the explanation....
let alone what load and line side on a GFI has to do with anything. (They are both hot (or neutral) unless tripped.)
Are you sure what you are saying.?????
Best
Old 07-20-2014, 09:06 PM   #12
Originally Posted by ddawg16 View Post
Troll in the house?
Lucky Dawgy..... Did I just get JO'd.
Old 07-20-2014, 09:57 PM   #13
Rewards Points: 455
Naw man. Real deal. some kitchen remodeler slapped in a 220V micro and 4 wire stove, so, closest thing to get a neutral was from another circuit on kitchen gfci to get the displays and lights working on stove and microwave. is that better ? when stove door was closed then it was an open path on neutral and when door open, it was a closed path.
Get it now ?
They were jacklegged in series
Old 07-20-2014, 10:29 PM   #14
Get it now ?
Cletis..... As explained (partially)... yes, it does possibly make sense with a tapped in series neutral.... but there would have been other pecularities like the stove would not work (120 lights) without the microwave working.(and yes, maybe there is a new 4-wire stove that has no 120 control lighting except for the interior light.... I have trouble believing it is made)
And you did say that the stove was wired SEU (I thought all SEU was three conductor... maybe I'm mistaken).... and you never disclosed the micro was 240 (which you have to admit that in most instances, it is fair to asume as 120).
Fun.... but tricky through deception/non-full disclosure.
( I have some lights in my game room circuit that won't go on. I have checked each outlet and the breaker, and all the GFI's, all wiring, and even each bulb.... I am sure all are working fine. What's your call?)
(Power went out in the city... I did not tell you the full story)
Best..... Ya got us
Old 07-20-2014, 11:54 PM   #15
JOATMON
ddawg16's Avatar
Any guesses ?
You could have explained this better. I understood it to mean the microwave started to cook....you didn't say the power came on.
The Following User Says Thank You to ddawg16 For This Useful Post:
MTN REMODEL LLC (07-21-2014)
AFI Problem (Very interesting) Hikyuuri Electrical 9 12-27-2012 07:48 PM
Problem with toilet (vent problem?) branch155 Plumbing 24 03-09-2012 09:37 AM
75 year chimney leak problem mstanleyg Building & Construction 10 03-30-2010 12:38 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
