Wall(wdw Size)air Conditioner(heat Pump) W/ Ldci 20 Amp Plug - Electrical - DIY Chatroom Home Improvement Forum
Old 08-06-2010, 04:18 PM   #1
wall(wdw size)air conditioner(heat pump) w/ ldci 20 amp plug
what wire size do I use for the red, black, white wires. run from source box is <40 ft
fog711 is offline   Reply With Quote
Old 08-06-2010, 04:35 PM   #2
Electrician
Proby's Avatar
A little more info will help. How are you running this line? Why do you feel you need a red wire? What is your location?
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
How to find out why your pool pump is not fully priming tripflex How To Guides 8 07-15-2015 06:15 AM
Sump Pump Questions henlij Plumbing 22 03-16-2015 11:00 PM
Low Well Pressure, Submersible Well Pump, Help Please! tpolk Plumbing 7 11-13-2009 07:13 PM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 07:10 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
