Wall Timer Wiring Issue - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-11-2012, 10:08 AM   #16
I have a similar issue and so need help with determining correct wiring.
Bought a GE digital timer switch to replace one 3-switch in the following:
Two 3-way switches control two outside lights. Each 3-way has two black and one red wire. Should I be able to simply replace one 3-way, using only the same wires?
GMAGDNA is offline   Reply With Quote
Old 02-11-2012, 11:18 AM   #17
Rewards Points: 2,516
Are your current setup of the two three-way switches functioning properly?
hammerlane is offline   Reply With Quote
Old 02-11-2012, 02:22 PM   #18
The current, standard 3-way switch set up is working correctly.
Old 02-16-2012, 11:57 AM   #19
Any thoughts as to if I should be good to use only the wires connected to the standard 3-way? I ask because 1) it's a $30 timer switch I don't want to burn up and 2) the instructions has two sets of directions based on if it's connected to load or line - but both my standard existing 3-ways seem to wired the same.
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
How to rough wiring in this wall WillK Electrical 13 07-17-2012 08:07 PM
Trying to install wall timer in place of switch bigcutts Electrical 3 02-02-2011 04:41 AM
help wiring a timer in a 3 gang light box edadmartin Electrical 3 03-14-2010 09:05 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
