In Wall Timer With Dimmer Function? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-31-2012, 03:10 PM   #1
Rewards Points: 45
In wall timer with dimmer function?
I have a 120v fixture that is currently on a dimmer switch but that I would also like to be controlled with a timer. Does such a switch exist that I can program for on off, and also dim?
kooshball is offline   Reply With Quote
Old 12-31-2012, 03:27 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,898
I've never seen one. You can combine them though. Replace the existing switch box with one that is one gang wider, and install a timer and a dimmer next to each other. Feed the dimmer from the timer.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 12-31-2012, 04:16 PM   #3
this might work
http://www.homedepot.com/buy/lutron-...t251hw-wh.html
Programmable in-wall dimmer with timer? kooshball Electrical 1 02-26-2012 08:00 PM
Wall Timer with 4 wires connecting to box with 3 wires LLeno22 Electrical 5 02-12-2012 09:57 AM
Trying to install wall timer in place of switch bigcutts Electrical 3 02-02-2011 04:41 AM
Wall timer wiring Jdf Electrical 3 07-16-2010 09:40 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
