In Wall Timer To Control Low Voltage Interior Lights? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-31-2012, 03:06 PM   #1
Rewards Points: 45
In wall timer to control low voltage interior lights?
I am looking for an in wall timer that I can use to control 120v that feeds a transformer that controls low voltage halogen lights. I have tried an in wall Tim before but it did not work and I suspect that it was due to the fact that it is feeding a transformer...
What switch do I need to buy to get this to work properly?
kooshball is offline   Reply With Quote
Old 12-31-2012, 03:25 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,864
Look for a timer that has a three-wire connection (power in, power out, and neutral), or that is rated for use with compact fluorescent lamps. That should work. The reason yours did not work is that the timer relies on leakage through the load when it's turned off in order to operate its circuitry. The lighting transformer (which I'm assuming is electronic) is not leaking current the way the timer needs it to.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Wall Timer Wiring Issue sjh5g Electrical 18 02-16-2012 11:57 AM
Help with wall switch - Constant voltage gambit023 Electrical 6 10-18-2011 10:30 PM
low voltage wiring in wall, suitable conduit Steve Burke Electrical 2 03-15-2011 03:11 PM
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 07:23 PM
Timer to control two electrical devices worahm Electrical 5 01-28-2010 09:06 PM
