Wall Timer With 4 Wires Connecting To Box With 3 Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 02-11-2012, 03:08 PM   #1
Wall Timer with 4 wires connecting to box with 3 wires
I just purchased a GE wall timer to install at my Mothers house. The plan here is for the timer (which is located inside the enclosed garage) to turn on/off the outdoor lights thereby increasing her comfort in the home at night. I removed the old switch only to find I had three wires - two white (one of which I know is the hot wire) and a ground breaker. The timer, however has four wires - red/black/white/green. I'm ok with the placement of the red/black and green wires but the white wire has me stumped. Can you offer any help?
LLeno22 is offline   Reply With Quote
Old 02-11-2012, 03:41 PM   #2
Many in-wall timers these days require a dedicated connection to neutral, which I believe is why you have a white wire on this switch. I'm sure one of the experienced electricians here can provide more detail.
LooseSCruz is offline   Reply With Quote
The Following User Says Thank You to LooseSCruz For This Useful Post:
LLeno22 (02-11-2012)
Old 02-11-2012, 03:58 PM   #3
Julius793's Avatar
Check the back of the box are there any neutrals?
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 02-11-2012, 10:08 PM   #4
I pulled the box completely out of the drywall and there are no other wires. I connected the red wire (Load) and the black wire the connected the white neutral wire to the grounded copper wire just to see what would g
Happen and the lights turned on. But I was afraid to leave the connection like that because I don't want to do the " wrong" thing even if it seems to be right
Old 02-11-2012, 10:27 PM   #5
Julius793's Avatar
Well DONT do it!!!! go get another timer that doesn't need a neutral.
The Following User Says Thank You to Julius793 For This Useful Post:
LLeno22 (02-12-2012)
Old 02-12-2012, 09:57 AM   #6
Thanks! I'm going to do just that.
Just a side note: I ended up checking the wall switch that turns on the flood lights in Mothers backyard and surprisingly, it had 2 black wires the ground wire AND two white wires (which where bound together and not in use). I installed the timer adding its white neutral wire to the two white wires in the box and the timer worked!
I'm going to check Lowes and Ace for a timer without the neutral wire for the first switch that prompted my initial post!
Tags
neutral wire , old wiring , timer , wall timer
Connecting 4 aluminum wires in a junction box krick Electrical 3 07-21-2012 03:06 PM
Question about connecting wires to the RTH2300 (honeywell) thermostat crap_at_diy HVAC 3 11-26-2011 11:50 PM
Timer switch has 4 wires. Only 3 wires on switch by itself. Now what. noone Electrical 11 11-15-2011 07:07 AM
Wall timer wiring Jdf Electrical 3 07-16-2010 09:40 PM
