Wall Switches In The UK, Repeat Jamming - Electrical - DIY Chatroom Home Improvement Forum
Old 11-20-2007, 06:01 AM   #1
wall switches in the UK, repeat jamming
I'm in the UK and have a wall switch (45amp double pole) from the mains to turn the shower on and off (the switch isn't in the shower room ).
About a month ago the switch jammed 'on' and wouldn't click off... no problem thinks I, and replaced the switch. Now the same thing as happened, this time jammed 'off'. The switch won't flip to the other position.
It seems to be a mechanical problem with the switch (electrics are all fine, nothing has tripped etc). Any ideas what could be causing it? The same thing happening to 2 switches seems unlikely.
Any help would be appreciated.
Jon
houseofathan is offline   Reply With Quote
Old 11-20-2007, 08:40 AM   #2
When you say 45 Amp double pole are you talking about the wall switch or the panel breaker protecting the branch circuit? Has the switch worked in the past? At 240 volts, 45 Amps is a lot of juice. Normally when a switch jams the contacts are welded shut which can be caused by more current flowing than the switch rating.
Edit: In most case a switch that jams due to the contacts being welded is a symptom not the cause of the problem. Most likely the load is the problem.
spebby is offline   Reply With Quote
Old 11-20-2007, 10:10 AM   #3
yup, it's a wall switch. the circuit welding the switch closed seems possible. The shower unit requires a mains feed of 45 amps, which is what the switch is rated at, so i'm going to try a higher amperage switch and take a closer look at the mains load (to check there's nothing strange going on).
thanks.
jon.
Old 11-20-2007, 01:09 PM   #4
My advice is to have the shower checked by a pro. If the switch is rated at 45 amps and the shower requires 45 amp service, then something is wrong with the shower. A higher rated switch will also fail or start a fire. I am not a pro, but have years of electrical experience.
Old 11-20-2007, 05:15 PM   #5
" Euro " electrician
frenchelectrican's Avatar
there are a possiblty that can cause the mess with the switch one is poor qualunty switch
second thing i am not sure if you are aware with this or not your shower heater required a RCD [ GFCI ] also
i dont know if that the case but it can if the wires or switch is mounted very tight and when get hot and it can screw up the connection..
hope that will answer the question here
Merci, Marc
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 03:49 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
