Wall Switch With Many Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 10-13-2012, 09:20 PM   #1
Question
Wall switch with many wires
Hello All!
I am adding some recessed lights to my home office and the light switch is a mess (to many wires running in and out. I am looking for some help. I disassembled everything and cant get it back together.
The set up is as follows:
1) There is one "hot" cable with a black / white / ground cable.
there are four cables feeding from this switch.
1) One cable is feeding the existing over head light. black / white / ground
2) Second cable is feeding one outlet below, not controlled by the switch. black / white / ground.
3) Cable feeding both an outlet and separate closet light (with separate switch, its a single pole). black / red / white / ground.
4) I added a new run to the recessed lights over head. black / white / ground.
How do I connect everything so i have this setup.
Two switches at the main location, one controlling the recessed lights and one controlling the overhead lights and everything else working independently.
Thanks You!
dan5.5 is offline   Reply With Quote
Old 10-14-2012, 06:33 AM   #2
Rewards Points: 2,516
see if this helps any...you are going to have to use pigtails from the incoming hot wire to feed both switches---the pigtails are shown with pink markings in the diagram
NOTE: I did not show ground wires for ease of drawing
hammerlane is offline   Reply With Quote
Old 10-14-2012, 10:30 AM   #3
Thanks! What do I do with red wire? Just cap it?
Also my switches are dimmers and they have only one of each connection. So I assume I would connect the pig tail to the black lead on the switch and the other black going to the lamp to the white on the dimmer?
Old 10-14-2012, 04:12 PM   #4
Didnt see the note about a red wire being part of one of the cables. What is this red wire connected to at its other end?
Old 10-14-2012, 04:36 PM   #5
Oso954's Avatar
Rewards Points: 1,010
"3) Cable feeding both an outlet and separate closet light (with separate switch, its a single pole). black / red / white / ground."
S/B either the switch or outlet, but I would want to confirm it before connecting it.
Oso954 is online now   Reply With Quote
Old 10-14-2012, 06:26 PM   #6
Licensed electrician
Rewards Points: 1,486
The red may be a switch controlled hot while the black is a constant hot.
You should not have a white on the dimmer. A switch only breaks the hot.
Old 10-14-2012, 06:49 PM   #7
Rewards Points: 372
Jim,
I'm watching this thread as I have a couple of similar switch arrangements.
What does the little purple bit in the two blacks going to the switches stand for in your diagram?
imautoparts is offline   Reply With Quote
Old 10-14-2012, 08:06 PM   #8
I marked the two blacks with the pink/purple just to depict those are what I refer to as pigtails. I do state that in the #2 post.
Light fan burn out, wall switch backwards later LOYD DUNCAN Electrical 1 09-18-2012 06:49 AM
Electrical wiring/ switch wiring - mixed wires tien009 Electrical 1 07-21-2012 10:53 PM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-08-2011 11:00 PM
Single Pole Light Switch with 4 Wires dmwiecz Electrical 6 11-22-2010 06:41 PM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
