-   -   Wall switch with many wires (http://www.diychatroom.com/f18/wall-switch-many-wires-159973/)
dan5.5 10-13-2012 10:20 PM
Hello All!
I am adding some recessed lights to my home office and the light switch is a mess (to many wires running in and out. I am looking for some help. I disassembled everything and cant get it back together.
The set up is as follows:
1) There is one "hot" cable with a black / white / ground cable.
there are four cables feeding from this switch.
1) One cable is feeding the existing over head light. black / white / ground
2) Second cable is feeding one outlet below, not controlled by the switch. black / white / ground.
3) Cable feeding both an outlet and separate closet light (with separate switch, its a single pole). black / red / white / ground.
4) I added a new run to the recessed lights over head. black / white / ground.
How do I connect everything so i have this setup.
Two switches at the main location, one controlling the recessed lights and one controlling the overhead lights and everything else working independently.
Thanks You!
hammerlane 10-14-2012 07:33 AM
1 Attachment(s)
see if this helps any...you are going to have to use pigtails from the incoming hot wire to feed both switches---the pigtails are shown with pink markings in the diagram
NOTE: I did not show ground wires for ease of drawing
dan5.5 10-14-2012 11:30 AM
Thanks! What do I do with red wire? Just cap it?
Also my switches are dimmers and they have only one of each connection. So I assume I would connect the pig tail to the black lead on the switch and the other black going to the lamp to the white on the dimmer?
hammerlane 10-14-2012 05:12 PM
Didnt see the note about a red wire being part of one of the cables. What is this red wire connected to at its other end?
Oso954 10-14-2012 05:36 PM
"3) Cable feeding both an outlet and separate closet light (with separate switch, its a single pole). black / red / white / ground."
S/B either the switch or outlet, but I would want to confirm it before connecting it.
Jim Port 10-14-2012 07:26 PM
The red may be a switch controlled hot while the black is a constant hot.
You should not have a white on the dimmer. A switch only breaks the hot.
imautoparts 10-14-2012 07:49 PM
Jim,
I'm watching this thread as I have a couple of similar switch arrangements.
What does the little purple bit in the two blacks going to the switches stand for in your diagram?
hammerlane 10-14-2012 09:06 PM
I marked the two blacks with the pink/purple just to depict those are what I refer to as pigtails. I do state that in the #2 post.
