Old 08-12-2008, 10:03 AM   #1
wall switch gets hot
Just bought a house (not new). The preveouse owner has can lighting in the kitchen with 65 watt 120v flood light bulbs. There are 8 lights running of this switch, the switch is also a dimmer switch. The plate gets warm and sometimes the screw actually feel hot after being on for a period of time. Do I have to have this rewired or are there heavy duty switches?
Thanks in advance for your help
Dave
couchguy is offline   Reply With Quote
Old 08-12-2008, 11:03 AM   #2
You may be pushing the capacity of the dimmer, especially if there are more than one switch in the box. You have ~520 watts of lights. Pop the cover off the switch and look on the switch, it should say its rated wattage. If I am remebering right, the one I installed says that it is rated for 600 watts if its the only switch in the box, 500 watts if it is next to another switch, and 400 watts if it is between two other switches.
They sell dimmers that are rated for more watts, I think the next standard is 1000 watts, you may want to get one of those.
daxinarian is offline   Reply With Quote
Old 08-12-2008, 11:58 AM   #3
Electrical Contractor
It is normal for a dimmer to feel warm when used to dim the lights.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 08-12-2008, 12:13 PM   #4
jbfan, how warm is warm? If you can't touch it for longer than a second without it hurting is that "warm" or "too hot"? How hot/warm is yours getting Couchguy?
Old 08-12-2008, 01:40 PM   #5
Power Gen/RS Engineer
Jbuffet is absolutely correct on this one: dimmers will get hot when they are set at anything but 100% full output. While a 600W dimmer is perfectly acceptable for loads up to and including 600W, as another poster mentioned, their rating must be de-rated when installed in a ganged arrangement. Also, with can lighting, the total load for a multiple-fixture arrangement must be computed based on the maximum lamp size that each can accommodate. This is not to say that you are not correct in basing your particular load on the actual bulbs installed (i.e. 65W) however.
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves,"You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." - George Carlin
BigJimmy is offline   Reply With Quote
Old 08-14-2008, 01:43 PM   #6
Thank you for all of your feed back. I would have to say based on what you described as hot I would say it is only warm. I have no prblem touching the switch for a long time. But to be safe it sounds as though I should make sure that either I make sure the switch is rated for 600 or put one in rated for 600 am I reading this correctly.
Old 08-14-2008, 03:01 PM   #7
I don't think you can find a dimmer rated for less than 600 watts.
Old 08-15-2008, 12:42 AM   #8
" Euro " electrician
frenchelectrican's Avatar
The most common dimmer size is 600 watts or larger.
It used have 300 watt rating few years back but not anymore due they get smoked up fast from overloading.
Yeah they do get very warm during operation espcally near full load on the dimmer.
Merci,Marc
Old 08-15-2008, 07:40 AM   #9
couchguy, Yes you are correct. Verify that the dimmer is rated 600W or better. If not, replace with a 600 or 1000w.
Pas de problème,il marche n'est-ce pas?"(No problem, it works doesn't it?)
(borrowed from another electrician (Marc) at another web site.....)
petey_c is offline   Reply With Quote
Old 08-15-2008, 12:13 PM   #10
sweaty
You could get dimmable CFL's, save electricity, and keep the same switch.
sweaty is offline   Reply With Quote
Old 08-16-2008, 01:45 AM   #11
Petey_C .,, That is my Quoteation from other website.
Et C'est Moi { And it is me }
Merci,Marc
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
ceiling fixture with on-off wall switch carlu Electrical 1 03-04-2005 09:13 AM
Wall Switch sue Electrical 4 02-06-2005 08:05 PM
