Wall Switch For Ceiling Fan / Light - Electrical - DIY Chatroom Home Improvement Forum
Old 03-03-2009, 06:28 PM   #1
Rewards Points: 150
Send a message via AIM to Bocolo
Wall switch for Ceiling Fan / Light
Hello,
I can't figure this out, perhaps someone could help me out. I have a ceiling fan / light that is currently controlled by a remote and it works fine. I would like to run a 3 wire cable and install a new wall switch. The power comes from the ceiling box via 12/2. This is what I am working with. Thanks for your time and input.
Wall switch for Ceiling Fan / Light-0303091855a.jpg   Wall switch for Ceiling Fan / Light-0303091857.jpg   Wall switch for Ceiling Fan / Light-0303091855.jpg   Wall switch for Ceiling Fan / Light-0303091854a.jpg   Wall switch for Ceiling Fan / Light-0303091853.jpg
Bocolo is offline   Reply With Quote
Old 03-03-2009, 06:45 PM   #2
Rewards Points: 266
At the fan box: Connect the incoming black wire to the white wire in your new 12/3 (reindentify this as a hot conductor at both ends)
Connect the black wire in your new cable to the hot wire going to the fan (usually black, but check)
Connect the red wire in your new cable to the hot wire going to the light
Connect the fan's white wire to the white wire in the incoming cable.
Connect your grounds together
At the switch box:
Connect your white wire (that you taped black) to the black wire on the fan control.
Connect the black wire in the cable to the yellow lead on the fan control.
Connect the red wire in the cable to the red wire on the fan control.
Connect your grounds.
junkcollector is offline   Reply With Quote
Old 03-03-2009, 07:16 PM   #3
Rewards Points: 150
Thanks. I think I see it know. I will try it over the weekend. Thanks again.
Old 03-08-2009, 09:56 PM   #4
Rewards Points: 150
Worked like a charm. Thanks for your time and input.
One Pound of Knowledge Requires Ten Pounds of Common Sense In Order To Be Useful
Hot light switch - how dangerous, and what to do? maximizer Electrical 12 12-29-2011 10:19 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Adding second light switch to an existing light TexasEd Electrical 7 08-15-2008 06:22 PM
Adding one recessed light to exsisting switch... JayBird Electrical 1 04-03-2008 07:32 PM
Help! wall light fixture w/ switch 8christiest Electrical 3 08-28-2007 03:21 PM
