Wall Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 02-06-2005, 12:19 PM   #1
sue
Cool
Wall Switch
I have two lights that use one single pole wall switch that I am replacing. I pulled out the wall switch from the wall and it is cracked where one of the wires is pushed in the back. I noticed that one wire is connected to the top screw and one wire is pushed in the back of the switch that is right next to the top screw. Are these two wires my two lights? There is a wire connected to the bottom screw and a wire connected to the ground screw. Also, the switch does not identify which wire is the common. How can I tell so I know which wire to connect to the new switch in the screw marked common? The wires consist of three black wires and one copper ground wire.
sue is offline   Reply With Quote
Old 02-06-2005, 03:28 PM   #2
Rewards Points: 150
what is the color scheme of the 4 wires you've described??
pipeguy is offline   Reply With Quote
Old 02-06-2005, 03:54 PM   #3
sue
The wires are three black and one copper ground wire.
Old 02-06-2005, 05:06 PM   #4
Rewards Points: 150
I don't think you should have a switch with a "common" terminal. The switch should have a gold colored terminal screw, a silver colored terminal screw and a green ground screw.
Old 02-06-2005, 08:05 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
If you have a switch with a "common" terminal you have the wrong switch (a 3-way).
You need a single pole switch, which will have TWO GOLD screws and a ground.
The two blacks which were together were the feeds (hots), one in and one out, but both hot wires. The single black is to the lights.
Connect the wires the same way as the old switch.
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 10:34 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 10:44 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
ceiling fixture with on-off wall switch carlu Electrical 1 03-04-2005 09:13 AM
