In Wall Speaker Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 03-22-2011, 08:17 AM   #1
in wall speaker wire
what will happen if non in wall speaker wire was ran behind dry wall
fernie is offline   Reply With Quote
Old 03-22-2011, 08:35 AM   #2
Coatings Nerd
What do you mean? If its a clean run, not touching anything, you're fine.
www.northcromwellpaint.com
Benjamin Moore, Sikkens, TWP, PPG, Airless sales and service
NCpaint1 is offline   Reply With Quote
Old 03-22-2011, 09:03 AM   #3
Licensed electrician
Rewards Points: 1,054
Wiring behind the building surface needs to be listed for use for those applications. It deals with flame spread and smoke production. These are speaker cables listed for in-wall usage.
Old 03-22-2011, 09:22 AM   #4
Coatings Nerd
Whats the difference if its inside a wall or laying on a floor. If the house is on fire, it's gonna burn regardless
Old 03-22-2011, 09:42 AM   #5
Jim's answer is the correct one; that being said, I'm kind of with you on this. I figure I have bigger things to worry about than speaker wire if my house is on fire. I used standard speaker wire up the walls and into the attic in my house, and I don't lose any sleep over it.
DetroitEE is offline   Reply With Quote
Old 03-22-2011, 10:06 AM   #6
Rewards Points: 1,418
The biodegrading characteristics of non-inwall rated wiring are unknown. I have seen speaker wire become discolored, although not waited (or haven't lived) long enough to see it actually disintegrate. I have seen other kinds of plastics (while we are on the subject of audio equipment: phonograph turntable mats) that had degenerated into a mushy mess and others that turned brittle and cracked (while not subjected to sunlight).
Old 03-22-2011, 10:07 AM   #7
The difference is I won't get a red tag from the inspector for installing a listed method behind the building surface.
Old 03-22-2011, 10:11 AM   #8
Coatings Nerd
Thats why you do it afterwards, everyone knows that
Im a hack, what can I say
Old 03-22-2011, 10:14 AM   #9
Coatings Nerd
My point exactly. How long did it take for that to happen? Years and years. Chances are, technology will initiate replacement before any failure arises. Inspectors dont care about that though I guess....and in my experience, they have no sense of humor either
Old 03-22-2011, 10:58 AM   #10
Rewards Points: 58
Hack. I agree.
Old 03-22-2011, 02:29 PM   #11
Rewards Points: 131
I used standard 12g speaker wire because I had a large spool remaining from monoprice but it does offer several types of wire.
Taken from Monoprice:
If you're looking for a décor friendly cable, look no further than the Monoprice CL2 rated speaker cable. They come with a white outer jacket to blend in with your walls and baseboards for out of wall applications and are CL2 rated to meet most building codes * for installation behind the walls when you want to keep the cables completely out of sight. These cables are made from high purity, oxygen free copper, are available in a variety of gauges and come in 2 conductor and 4 conductor configurations. The 4 conductor cables are perfect for bi-wiring high end tower speakers that offer a bi-wireable option.
Features:
  • Perfect for use in or out of wall with a variety of speaker types including in-wall and in-ceiling.
  • Compatible with banana plugs.
  • Clearly distinguishable Red and Black inner jackets for determining polarity.
  • High quality, flame retardant PVC outer jacket.
  • Multi-twist, rope lay braiding.
  • UL listed and CL2 rated.
Local building codes can vary from region to region. Check with your local fire department to find out what the requirements are for your area.
HitLines is offline   Reply With Quote
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 09:22 AM
Proper way to leave unused wire in wall psuryan Electrical 3 10-26-2010 09:16 PM
Speaker wire in walls LeviDIY Home Theater 12 11-07-2009 03:56 PM
Running a wire through the wall RegeSullivan Electrical 1 09-27-2009 09:28 AM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
