#1 |
in-wall speaker wire?
Hi,
I'm currently renovating a house I intend to live in. It's down to bare studs... perfect time to set up that wired surround-sound system but make it look wireless ![]() What should I run through the walls for speaker wire? Your standard speaker wire isn't well-insulated, and isn't recommended... so what IS recommended? What wire have others run for speakers? Thanks! Don |
#2 |
I use speaker wire
Simple 16-2 works fine for me. |
#3 |
in-wall speaker wire? |
#4 |
Licensed electrician
Some systems use CAT5 cable to distribute to volume controls and then speaker wire from the control to the speakers.
#5 | |
Licensed Electrical Cont.
in-wall speaker wire?Quote:
Not all are the same. You CANNOT use "standard" speaker wire in wall. It MUST be in-wall rated. Read this: http://www.audioholics.com/education...-cable-ratings
Sometimes I feel like if I answer any more questions it is like someone trying to climb over a fence to jump off a bridge and me giving them a boost. |
#6 | |
Or.....it will catch fire? |
#7 |
Electrician
#8 | ||
I'm okay with simple (ie 16-2 wire) but adding a "control" run like cat5 would be easy enough too, even if I don't end up using it. Is that worth while?
#9 |
Sure, Cat 5 is cheap enough to take than chance that you'll need it.
Personally I would pick a system first then find out what to run.
#10 |
Hey 220. I wouldn't expect any less of a reply from you.
The stuff I get is around $70/500' for 16/2. Cheap enough to do the right thing. What do you use? Lamp zip cord?
#11 |
Electrician
#12 | |
What is the difference between zip cord, speaker wire and rated speaker wire? It is SPEAKER wire. I say there is no difference. Teach me something. |
#13 |
Sorry bud, that's not my job. This is stuff you should know already, I shouldn't have to teach you.
That link I posted has some very good information. Way back I used to have to run zip type cord for speakers because I didn't know any better and that's what I was told to do. That is until I questioned it like the tons of other things I questioned, and still do. Then I found out what was proper and correct for the application. I was pretty green back then. Don't get me wrong, I'll admit that zip cord for speakers is not something that will likely burn a house down, but why bother doing it wrong when doing it right is just as easy. For a while now I have realized that there is a VERY little difference in doing the right thing and not doing the right thing. This speaker wire situation is a perfect example. The cost and effort difference between doing the right thing and not is negligible, ESPECIALLY if you are doing this for a living.
#14 | |
So...you're sayin you don't know? It is my nature to ALWAYS ask why, to question authority if you will. If I can't figure out why, I will ask someone. If no one knows I just use my best judgement whether or not to accept the fact. |
#15 |
Hah! I just did the same thing.
I used CL3-rated 16 awg wire for my in-ceiling speakers. For my towers, I used CL3-rated speaker wire. You need CL3-rated wire for in-wall installations. From my research most people couldn't tell the difference between the gauge. CAT-5 is okay for control or if you have IP-speakers which are really expensive, but I wouldn't run your signal over the CAT-5. |
| Display Modes | |
| speaker wire | JAVAMAN | Home Theater | 4 | 03-12-2008 08:40 PM |
| Raising Doorway Height (load bearing?) | treefrog | Building & Construction | 6 | 02-25-2008 10:11 PM |
| Marrying a sloping stone wall to a cinder block wall. | mrdol | Landscaping & Lawn Care | 1 | 11-09-2007 05:08 PM |
| Atlantic-need your opinion on markd's comments about my vapor barrier? | yummy mummy | Building & Construction | 11 | 03-07-2007 10:47 AM |
| Flat Speaker Wire | Dustin07 | Home Theater | 3 | 01-17-2006 10:40 PM |
