-   -   in-wall speaker wire? (http://www.diychatroom.com/f18/wall-speaker-wire-19666/)
radon 04-08-2008 06:36 PM
Hi,
I'm currently renovating a house I intend to live in. It's down to bare studs... perfect time to set up that wired surround-sound system but make it look wireless :)
What should I run through the walls for speaker wire? Your standard speaker wire isn't well-insulated, and isn't recommended... so what IS recommended? What wire have others run for speakers?
Thanks!
Don
220/221 04-08-2008 06:39 PM
I use speaker wire :laughing:
Simple 16-2 works fine for me.
jerryh3 04-08-2008 06:55 PM
http://www.bluejeanscable.com/articles/inwallrating.htm
Jim Port 04-08-2008 07:12 PM
Some systems use CAT5 cable to distribute to volume controls and then speaker wire from the control to the speakers.
Speedy Petey 04-08-2008 08:44 PM
Well what system are you using?
Not all are the same.
You CANNOT use "standard" speaker wire in wall. It MUST be in-wall rated.
Read this: http://www.audioholics.com/education...-cable-ratings
220/221 04-08-2008 11:27 PM
Or.....it will catch fire?
chris75 04-08-2008 11:51 PM
Nope worse, you wont get your Certificate of Occupancy...
radon 04-09-2008 06:32 AM
Yeah that's what I'm concerned about. So there's in-wall rated speaker wire?
Don't have a system yet - don't even have walls :) I'm okay with simple (ie 16-2 wire) but adding a "control" run like cat5 would be easy enough too, even if I don't end up using it. Is that worth while?
Speedy Petey 04-09-2008 06:56 AM
Sure, Cat 5 is cheap enough to take than chance that you'll need it.
Personally I would pick a system first then find out what to run.
Speedy Petey 04-09-2008 06:58 AM
Hey 220. I wouldn't expect any less of a reply from you. :thumbsup:
The stuff I get is around $70/500' for 16/2. Cheap enough to do the right thing.
What do you use? Lamp zip cord?
chris75 04-09-2008 08:55 PM
Hahahahahahahahahaha...... :laughing::laughing::laughing:
220/221 04-10-2008 12:15 AM
It wasn't a reply numbnuts, it was a question.:laughing:
What is the difference between zip cord, speaker wire and rated speaker wire? It is SPEAKER wire.
I say there is no difference. Teach me something.
Speedy Petey 04-10-2008 07:04 AM
Sorry bud, that's not my job. This is stuff you should know already, I shouldn't have to teach you.
That link I posted has some very good information.
Way back I used to have to run zip type cord for speakers because I didn't know any better and that's what I was told to do. That is until I questioned it like the tons of other things I questioned, and still do. Then I found out what was proper and correct for the application. I was pretty green back then.
Don't get me wrong, I'll admit that zip cord for speakers is not something that will likely burn a house down, but why bother doing it wrong when doing it right is just as easy.
For a while now I have realized that there is a VERY little difference in doing the right thing and not doing the right thing. This speaker wire situation is a perfect example. The cost and effort difference between doing the right thing and not is negligible, ESPECIALLY if you are doing this for a living.
220/221 04-10-2008 07:42 PM
So...you're sayin you don't know? :laughing:
It is my nature to ALWAYS ask why, to question authority if you will. If I can't figure out why, I will ask someone. If no one knows I just use my best judgement whether or not to accept the fact.
gfchew 04-10-2008 07:51 PM
Hah! I just did the same thing.
I used CL3-rated 16 awg wire for my in-ceiling speakers. For my towers, I used CL3-rated speaker wire. You need CL3-rated wire for in-wall installations.
From my research most people couldn't tell the difference between the gauge.
CAT-5 is okay for control or if you have IP-speakers which are really expensive, but I wouldn't run your signal over the CAT-5.
