In Wall Speaker Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 10-30-2013, 09:48 PM   #1
Rewards Points: 172
In wall speaker wire
I will be running speaker wire and rca's through my walls/attic for surround sound. Is there a certain type required for in the wall? Is there any codes for this?
nateshirk is offline   Reply With Quote
Old 10-30-2013, 10:14 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
The cables must be rated for in-wall use. Your everyday speaker wire is not so rated.
Old 10-31-2013, 12:24 AM   #3
Rewards Points: 172
Would any decent rca's work? Or do they have to be special too?
Old 10-31-2013, 01:31 AM   #4
Rewards Points: 6,652
Forget RCA cables, use RG-6 for any audio & video. As for the wire, CL-2 from Monoprice is fine. As for the Coax, you can use also the raw bulk coax from Monoprice.com, but make sure that it is the Solid Copper stuff, not Copper coated.
The Perfect Vision RG-6 bulk will work fine. It is the same stuff that DirecTV uses for their installs. http://www.amazon.com/Perfect-Vision...pd_sim_sbs_e_3
You can also get the Compression RCA connectors for the ends, instead of going from a "F" catv fitting with a screw on RCA type. http://www.amazon.com/s/ref=nb_sb_no...ca%20connector
Now if you are going to do HDMI also, suggest using Cat-6 for the runs. You can get by with Cat-5e, but it is just easier to future safe it for 4k UHD, by going with Cat-6 for those runs.
Centralize everything in a closet, do not take the runs into some bedroom closet. If you have a Utility room, place the equipment there, or in a dedicated closet. Also make sure that you have a Heat & Photoelectric/Ion smoke detector in that closed closet, so you can be warned if any equipment puffs the magic smoke. Also if you are going to place all equipment in a central closet, get yourself some type of remote temp & humidity monitor, that you can either read through your smartphone or tablet, or through a remote station. Something like the Radioshack Indoor/Outdoor weather station with remote sensors works fine for this.
Old 10-31-2013, 06:27 AM   #5
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
most speaker/amplifier connection do not need "ends" ..
here is the wire unless you are going super high end ..
http://www.lowes.com/ProductDisplay?...llow&cId=PDIO1
you do not need to run HDMI cable to the speakers . ..or coax for that matter ...
and http://www.amazon.com/s/ref=nb_sb_no...ca%20connector would be rediculous .....IMHO
terminate your speaker wires to a block at your main location ..... like this ...
any combination of the above you can get many many options ..
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 10-31-2013, 10:35 PM   #6
Rewards Points: 172
Holy crap Gregzoll. I'm not going all out like that. I'm just running speaker wire from my receiver to behind the couch for the rear speakers, and a single rca for the subwoofer.
If I'm running the rca for the sub about 60ft., is there anything in particular I should look for as far as cable quality?
The Following 2 Users Say Thank You to nateshirk For This Useful Post:
Philly Master (11-01-2013), stickboy1375 (11-01-2013)
Old 11-01-2013, 12:37 PM   #7
MarginallyQualified
Rewards Points: 2,464
If it's IN a wall or IN a sealed floor joist... it NEEDS to be CL2.
If it's just stapled to open framing it doesn't.
Then you get into signal quality which CL2 also manages well.
I'd bought the 14ga 4 wire... Doubled up 2 wires might suit.
You can buy it by the foot in most cities.
Old 11-01-2013, 01:32 PM   #8
Again, just use Solid Copper RG-6, and it would be best to use the Compression type fittings, vs. the screw on RCA to Coax fittings.
Old 11-04-2013, 01:15 PM   #9
Rewards Points: 172
Will this be cheaper than buying a rca cable of same length?
Old 11-04-2013, 04:30 PM   #10
Yes, a lot cheaper. Majority of RCA cables at that length, the ends are cheap to begin with. Also you are talking about the fact that the cables are not going to be rated for in wall use to begin with. That is why RG-6 Coax is used for any type of Audio or Component with RCA connection.
Old 11-04-2013, 04:32 PM   #11
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,972
For one cable just buy it. You can get a CL2 rated RCA cable.
Old 11-06-2013, 10:16 AM   #12
Rewards Points: 768
here an example
http://www.cablewholesale.com/produc...10r4-21150.php
carmusic is offline   Reply With Quote
Old 11-06-2013, 07:14 PM   #13
Rewards Points: 516
In real AUDIO they do not use RCA connectors ...just look at the back of any decent amp .... or coax for speakers ...
Old 11-06-2013, 07:19 PM   #14
Rewards Points: 516
everything you need is on this page ....
http://www.monoprice.com/Product?seq...Fc-Y4Aod3w0AkQ
and do not use less than 18 gauge wire !!!
http://www.monoprice.com/Product/?c_...1&format=6#faq
The Following User Says Thank You to Philly Master For This Useful Post:
tribe_fan (11-07-2013)
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Subpanel wire through exterior wall Sully313 Electrical 26 05-19-2012 10:17 AM
tacking wire in wall Clutchcargo Electrical 4 10-08-2011 09:32 AM
Moving Speaker Wire in Drywall WirelessG Drywall & Plaster 19 09-16-2010 11:47 AM
Speaker wire in walls LeviDIY Home Theater 12 11-07-2009 02:56 PM
