Wall Socket Question - Electrical - DIY Chatroom Home Improvement Forum
Old 12-17-2012, 10:18 AM   #1
Wall socket question
I am replacing a standard in line wall socket (2 white and 2 black wires) with a specialty socket that only has 1 screw on each side of the socket. Is it best to join the wires together and add a pig tail to the new socket rather than trying to put 2 wires on each socket screw?
Bob60 is offline   Reply With Quote
Old 12-17-2012, 10:20 AM   #2
Licensed Pro
Pigtailing the wires is your only choice... two wires under a screw is not allowed.
Old 12-17-2012, 10:28 AM   #3
Thanks, that is what I figured but it never hurts to ask. Are standard marketers connectors what I should use for each set of 3 wires?
Old 12-17-2012, 10:29 AM   #4
Ipad issues - should read marette
Old 12-17-2012, 10:34 AM   #5
Rewards Points: 1,442
Yes, marettes (wire nuts) are the standard way of bundling the wire ends as discussed here.
They come in different sizes for the number and size of wires to be joined.
Two wires under one screw are permitted only when the screw terminal is designed for that purpose; where there are grooves or a cap piece that hold both wires in place not curled and not criss crossing, and they can't slip out sideways even partially just before the screw is tightened.
Where you could attach both wires directly to the device (receptacle, etc.) and by fielders choice or otherwse connected the incoming and continuing hots directly to each other with a pigtail, then you must pigtail the neutral similarly. It isn't good to find the hot still connected downstream and the neutral path broken for any length of time if you were doing some maintenance and uninstalled the receptacle. The neutral throughout the downstream portion of the circuit would be live if you turned the power on before finishing the job and something downstream was switched on. And you could be confused since the item you switched on would not work without the neutral path re-completed.
Meter socket distance from wall 7SistersRanchTX Electrical 2 02-28-2012 11:40 AM
basement partition wall - framing question RCharles Carpentry 3 08-18-2011 09:19 PM
Hood / Microwave Exhaust Vent, Wall question tameanaka Building & Construction 5 09-21-2010 03:44 PM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
