Wall Sconces From An Outlet? Illegal? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-12-2011, 03:48 PM   #1
Rewards Points: 191
wall sconces from an outlet? Illegal?
Hello and thanks to all ..
Remodel includes adding wall sconces around a mirror and was wondering ..
Is it illegal to use an existing outlet to run the lights and switch off of?
This would, by far, be the easiest way to accomplish what we are doing but it needs to pass inspection (California)..
Thanks in advance.
___
beachfront71 is offline   Reply With Quote
Old 07-12-2011, 03:58 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 654
Depnds!
Bathroom, maybe, Kitchen , No!
Where is the receptacle, and what is it feeding?
jbfan is online now   Reply With Quote
Old 07-12-2011, 06:32 PM   #3
Rewards Points: 191
Thanks. ..
The outlet is the last outlet on a GFCI run .. the lighting would be 2 wall sconces ...
Old 07-12-2011, 07:05 PM   #4
Licensed electrician
Rewards Points: 1,892
Without knowing what the GFI is specifically feeding I would say you cannot add the sconces. Most GFI protected circuits in a dwelling are rather strict about the loads they can serve.
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
Strange problem w. wall outlet, please help! yiplong Electrical 15 07-22-2008 04:02 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
