Wall Sconces - Electrical - DIY Chatroom Home Improvement Forum
Old 06-17-2008, 01:01 PM   #1
Question
Wall Sconces
I tried to replace two bathroom wall sconces in a 20-year-old mobile home yesterday. Both are controlled by a single wall switch.
Behind Sconce 1 (to the right of the mirror), were two sets of wires: black, white, ground. I connected all the blacks, all the whites, and the grounds, and the light works fine.
Behind Sconce 2 (left of the mirror) was ONE set of wires. I connected black to black, white to white, ground to ground.
Sconce 1 lights; Sconce 2 does not.
I'm wondering: are the sconces wired in series? Should I run two blacks from Sconce 1 to power Sconce 2?
Thanks.
Doug
DEG55 is offline   Reply With Quote
Old 06-17-2008, 01:22 PM   #2
Licensed Pro
Check your connections at both lights and check your bulbs.
Old 06-17-2008, 01:51 PM   #3
Thanks househelper.
The connections at both lights are secure, and I used the same lightbulb to check each light. That's why I'm puzzled.
Old 06-17-2008, 02:49 PM   #4
joed's Avatar
Rewards Points: 12,010
You have it wired correctly. One of the connections is bad or the fixture is bad.
Old 06-17-2008, 03:09 PM   #5
Licensed Pro
With the power off, look inside the lamp socket of the non-working fixture and gently pull up the center tab a little bit. If this doesn't do it, return the fixture.
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Wall Sconces helpless handyman Electrical 4 11-14-2006 05:18 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
