Old 01-22-2013, 02:42 PM   #1
wall sconce question
What type of gang box should I use for interior wall sconce?
zephead is offline   Reply With Quote
Old 01-22-2013, 02:52 PM   #2
To be 100% sure you would need to check the specs for the actual light you intend to install.
My first instinct would be a single gang box mounted sideways. This is only because you say wall sconce. I have a vision of a fixture that shines up which leave little room at the lower part of fixture for wiring so sideways works better.
It could be a round box a single gang mounted vertically or single gang mounted sideways. I have run into all of these instances.
If I knew absolutely nothing about the type of light going in, I may lean towards a single gang mounted vertically.
Typical wall mounted bathroom light fixture uses a round box.
Sorry for the non specific information.
parman is offline   Reply With Quote
Old 01-22-2013, 03:20 PM   #3
I really haven't picked out a fixture yet, just doing the prewire. But I do know I want the light pointing to the ground. Thanks for the info ill pick out a light before I install the box that way I can check the specs
Old 01-22-2013, 11:38 PM   #4
first off i have to ask, why do you want a wall sconce??? i hate them. i have to see them every day. now the ones i have are mounted like this....
vertical, hard to tell from that pic
redman88 is offline   Reply With Quote
Old 01-23-2013, 08:11 AM   #5
E2 Electrician
stickboy1375's Avatar
And? The OP wants them...
Old 01-23-2013, 05:34 PM   #6
eastcoastsparky's Avatar
Who cares what you think
Sent from my iPhone using DIY Forum
eastcoastsparky is offline   Reply With Quote
Old 01-23-2013, 05:41 PM   #7
Master Electrician
Most fixtures are best mounted using a round or octagonal box. However, some sconces are so narrow that a rectangular switch box mounted vertically is necessary or the sconce will not cover the hole.
brric is offline   Reply With Quote
Open Web Truss/ Load Bearing Wall Question rlc2052 Flooring 3 03-05-2010 10:37 AM
Question about removing trim wall in foyer cary00silve Remodeling 1 02-02-2010 01:02 PM
Framing Question: How thick the wall that carries plumbing? jaes Carpentry 5 06-18-2008 06:39 PM
Basement knee wall question vugger Building & Construction 2 01-05-2008 10:02 PM
Garage wall construction question Bjonas Building & Construction 4 01-01-2008 05:18 PM
