wall sconce question
What type of gang box should I use for interior wall sconce?
To be 100% sure you would need to check the specs for the actual light you intend to install.
My first instinct would be a single gang box mounted sideways. This is only because you say wall sconce. I have a vision of a fixture that shines up which leave little room at the lower part of fixture for wiring so sideways works better. It could be a round box a single gang mounted vertically or single gang mounted sideways. I have run into all of these instances. If I knew absolutely nothing about the type of light going in, I may lean towards a single gang mounted vertically. Typical wall mounted bathroom light fixture uses a round box. Sorry for the non specific information. |
I really haven't picked out a fixture yet, just doing the prewire. But I do know I want the light pointing to the ground. Thanks for the info ill pick out a light before I install the box that way I can check the specs
first off i have to ask, why do you want a wall sconce??? i hate them. i have to see them every day. now the ones i have are mounted like this....
http://i277.photobucket.com/albums/k...982/photo6.jpg vertical, hard to tell from that pic |
Sent from my iPhone using DIY Forum |
Most fixtures are best mounted using a round or octagonal box. However, some sconces are so narrow that a rectangular switch box mounted vertically is necessary or the sconce will not cover the hole.
| All times are GMT -4. The time now is 11:33 PM. |
