In Wall Programmable Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 10-07-2010, 02:16 PM   #1
Hello,
I have a light switch on my second floor that controls the Pot Lights outside our home. Recently I tried to swap out the switch with a programmable light switch so we wouldn't have to keep running upstairs to turn the outside lights on and off. The switch that I had purchased wasn't the right type as it required 2 Black wires. On my existing switch i only have a white, black and ground. The electrician must have run a dedicated line directly to one of the lights, and then daisy chained them together and installed the switch. Does anyone know of any in-wall timers that would work with a 2 wire setup?
amardeepj is offline   Reply With Quote
Old 10-07-2010, 03:17 PM   #2
Just call me Andrew
Rewards Points: 1,020
Which timer switch did you buy (make and model). It likely requires two hot wires, a neutral, and a ground...
You only have two wires in your switch box, correct? did you look behind the switch for two white wires in a wire nut? I am assuming you do not have this since the two wires you mentioned were black and a white. This is probably a "switch loop" - which has no neutral.
That being said, I think there are in-wall timers that don't require a neutral. They probably will not work with fluorescent bulbs (or CFLs).
Andrew
secutanudu is offline   Reply With Quote
Old 10-07-2010, 03:22 PM   #3
Just call me Andrew
I think this timer works without a neutral.
Edit: looks like I was right:
http://customer.honeywell.com/techli...00-032-001.pdf
But it does say in that PDF:
"The TI032-3W switch cannot be used with a load below 40 W or above
500 W."
I assume that means CFLs are out of the question.
Andrew
Old 10-07-2010, 03:51 PM   #4
Hello Andrew,
The bulbs I am using are PAR20 Halogen bulbs that are 40 watts each.. I have 11 pot lights outside so I am under 500 watts. I think this may be what I am looking for. I can't remember the name of the one I had bought before. I pulled the switch out and there is no wire nut. Only the Black White and Ground connected. I will do some more research on the one you have suggested and see if I can give it a try.
Thanks for your Help!
Edit:
The one I tried before was the Leviton 6124H Programmable Timer.
http://www.smarthomeusa.com/Products...s/6124Hins.pdf
As the manual shows, The white and blue go to the light, and black and green go hot and ground. This setup didn't work for me since I only have a Black, White and Ground. I was unsure if I could have connected the Black and Blue on the switch together to the Black going to the Load.
Old 10-07-2010, 04:01 PM   #5
DIYer
If it doesn't have a neutral, then all the current it draws has to pass through the load. A normal light will pass a little current through the filament without lighting up at all, so that's OK.
But a CFL looks more like an open circuit before it strikes. Halogen is OK.
Gigs is offline   Reply With Quote
Old 10-07-2010, 05:30 PM   #6
Just call me Andrew
amardeepj, I think that honeywell timer (or any that doesn't require a neutral) will work just how you want it to.
Andrew
Old 10-08-2010, 10:20 AM   #7
I had seen a GE timer model 15266 at Home Depot that claims that it works on Single Pole installations, however I was a bit hesitant to buy it since I cannot find any manual online to verify if it supports my setup or not.
Old 10-08-2010, 03:59 PM   #8
Just call me Andrew
That timer says it's "CFL Ready". That leads me to believe it requires a neutral.
Andrew
Light switch failure help!! metalrex Electrical 22 02-04-2010 10:13 PM
Add new light and switch to a switch loop UncertainSparky Electrical 4 01-24-2010 09:58 AM
Grabbing power from a light switch box RedBear Electrical 3 01-13-2010 02:28 PM
What wall switch for bath fan/light/heater? janralix Electrical 6 07-20-2009 12:14 PM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 10:44 PM
