Wall Oven Wiring Quick Question - Electrical - DIY Chatroom Home Improvement Forum
Old 11-17-2009, 03:30 PM   #1
wall oven wiring quick question
I need to replace my wall oven. It is on a standard 4 wire 220v circuit. The specs call for a 220v max 20 amp circuit. The breaker is a 20amp double pole. (2 20's ganged together, one for each hot). Does my current breaker / circuit configuration meet the requierments for the new oven?
205bhamjim is offline   Reply With Quote
Old 11-17-2009, 03:45 PM   #2
300zx's Avatar
Post
As long as your new wall oven does not require a different amp
300zx is offline   Reply With Quote
Old 11-17-2009, 03:54 PM   #3
thanks. If it calls for max 15 amps, can I just replace the 2x20 breaker with a 2x15? I guess what I'm asking is I can always go down but if I go up in amps I need to make sure the line can handle it. Sorry for being a rookie.
Old 11-17-2009, 04:01 PM   #4
300zx's Avatar
Yes you can change out to 2 pole 15 amp just can't go above what the wire can handle
What size breaker for 4100 watt wall oven? romexican Electrical 3 09-15-2009 10:34 PM
Removing built in oven to access wiring? Michman63 Appliances 1 09-03-2009 07:05 AM
Painting 2-tone on a single wall question lmholmes11 Painting 3 07-18-2008 10:43 PM
Framing Question: How thick the wall that carries plumbing? jaes Carpentry 5 06-18-2008 06:39 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
