Wall Oven Whip Cable Type - Electrical - DIY Chatroom Home Improvement Forum
Old 11-19-2012, 10:30 PM   #1
Hello. I just received a wall oven with a whip line that is made of 1/2" non-metallic sheathing with 4 separate conductors. The conductors appear to be no larger than 10 gauge and occupy less than half of the sheathing volume. I would like to route the line up and behind the oven within the cabinet, but the sheathing is a bit too thick. I have 8 gauge romex (correct number of conductors & NM-B) that would fit perfectly but wonder if there are temperature issues or other reasons to reject the idea. Thanks!
traffic_ahead is offline   Reply With Quote
Old 11-20-2012, 06:40 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Yes there are temp issues.
That is the reason the wire is a smaller gauge then you have to use to feed the oven with.
jbfan is online now   Reply With Quote
Old 11-20-2012, 09:02 AM   #3
Licensed electrician
Rewards Points: 1,876
The whip is made to connect to a junction box where the building wiring connects to it. The instructions will tell you where the box can be located.
Be sure to put a connector on the end of the flex.
Wall oven microwave combo patrick584 Electrical 6 09-02-2012 10:25 PM
Installing a wall oven suncowiam Electrical 11 10-31-2011 04:19 PM
Built-In (back) Oven Clearance for NM Cable? dcarpen23 Electrical 4 08-29-2011 11:29 PM
What type of cat5e cable type fastener? Ranger31 Electrical 8 06-29-2011 09:01 AM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
