-   -   Wall Oven blocked by Electrical (http://www.diychatroom.com/f18/wall-oven-blocked-electrical-156597/)
heyjoe91 09-12-2012 09:45 AM
You guys have been so helpful in the past. It's going to be very hard to explain my issue but I'll try.
I have a double Jenn Air 220 oven that I am trying to install in my kitchen. The oven is 30" wide. The electrical coming out of the oven is on the right side. On both sides of the back of the oven there is a 4" cutout from top to bottom. So only 22" actually goes all the way back to the wall. The fat BX coming out of the oven is meant to sit in the 4" notch out. Unfortunetely, in the wall behind the 4" notch is a 2x4 with barely enough room for a small box. To make matters worse there is a heating vent running right up against the 2x4. Taking out the vent is out of the quesiton. I tried installing the box on the other side of the 2x4 but the oven won't push in all the way. I even cutout a notch under the oven bottom board to give the wire more space but since the BX on the oven wire is so thick there is no flexibility in the wire. The wire will barely bend at 90 degrees. Remember the wire has to come down the over then 90 degree turn towards the wall and then another 90 degree turn up to the box.
This isn't so much an electrical issue but thought you may have dealt with this in the past. Can I break the bx casing to allow for more flexibility? I am worried that the wire could get cut by the sharp bx end. Any advice is appreciated.
Jim Port 09-12-2012 10:03 AM
Can you post a pic? Most times the box is surface mounted and the flex goes into the side of the junction box at the top of the oven.
heyjoe91 09-12-2012 10:09 AM
I am trying to upload a drawing I did in paint but it isn't working.
The old box that was in there for the old oven was mounted on top of the wall since only a small portion of the old oven went all the way back to the wall. This oven doesn't have that much room so I punched a hole in the wall and mounted a box.
heyjoe91 09-12-2012 10:25 AM
1 Attachment(s)
Here is a drawing. I had to shrink it down a little. Hope you can still get the idea.
Gac66610 09-12-2012 07:20 PM
What cabinets surround the oven, would it be possible to install the J-box through a hole into another cabinet? Even one below or above the oven.
Yes, have run into this before, yes PITA
andrew79 09-13-2012 12:01 AM
I'll answer the obvious question. No you cant break the armour for more flexibility
allthumbsdiy 09-13-2012 01:58 AM
what is the model #?
