Wall Oven - Electrical - DIY Chatroom Home Improvement Forum
Old 03-13-2007, 12:08 AM   #1
Wall oven
Hi there.
I just removed my old electric range-oven and replaced it with a new wall oven.
The new oven is rated 21 amps/5.1 kw which is a little bit less than the old range.
Would my old 8/3 cable and 40 amp breaker still be OK to provide power to the new wall oven.
Cheers,
Rusty.
rusty_5620 is offline   Reply With Quote
Old 03-13-2007, 04:39 PM   #2
Electrician
Rewards Points: 802
Hi there
Ideally this would be on a 30A breaker for proper protection.
Does your current wire have a ground in it. If it does I would recommend changeing the breaker to a 30A breaker and leaving the wire as is. If there is no ground wire I would recommend changeing the wire out with a new one. On a 30A breaker you could run #10 and be good.
Darren
darren is offline   Reply With Quote
Old 03-13-2007, 11:05 PM   #3
Hi Darren
Yes there is a ground plus the other three wires. Does the 30 amp 2 pole breaker just make it safer from possible shock more than anything else.
Regards,
Rusty.
Old 03-13-2007, 11:57 PM   #4
Rewards Points: 150
you don't want to pull too much current before the breaker trips and burn anything up.
did you consult the installation manual?
elementx440 is offline   Reply With Quote
Old 03-14-2007, 01:53 AM   #5
As I stated in my original post the wall oven only draws 21 amps which is less than most electric ranges.
The 8/3 with 40 amp breaker was already there from the old range.
Old 03-14-2007, 04:50 AM   #6
The wire will be fine. Does the cord on the wall over plug direcly into the old recepticle?
If not, you can just buy a 2 pole 30 amp breaker and replace the old 2p40 that feeds the circuit now, leaving the old wire in place.
Master Electrician
jwhite is offline   Reply With Quote
Old 03-15-2007, 01:18 AM   #7
Howdy
Hard wired it to the new whip in a junction box below the wall oven.
Put the new 30amp 2 pole in today.
Cheers,
Rusty
Rusty
Replace Cripple Wall to Raise Foundation? casey_wa Building & Construction 1 08-04-2007 04:32 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 03:49 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
