Wall Outlets Go Out When Raining - Electrical - DIY Chatroom Home Improvement Forum
Old 03-08-2013, 01:08 PM   #1
Rewards Points: 16
Wall outlets go out when raining
Whenever it rains (thankfully not too often in Southern California), the outlets in all three of the bathrooms go out. I can re-set the GFCI (which is in the garage), but the re-setting time can vary. Sometimes, i re-set it right after it trips, and it takes right away (the re-set button doesn't pop back out), other times, I have to wait and keep trying half-a-day to two-days until the re-set works.
The three bathrooms are the only thing in the house that goes out with rain
What should I be checking?
Thank you.
cl6120 is offline   Reply With Quote
Old 03-08-2013, 01:19 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,852
Exterior receptacles. You have some exterior wiring that is protected by the bathroom GFCI, and it is getting water in it and causing a ground fault.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 03-08-2013, 01:20 PM   #3
MarginallyQualified
Rewards Points: 2,464
Originally Posted by cl6120 View Post
Whenever it rains...
the GROUND FAULT outlets in all three of the bathrooms go out.
Find the fault.
Offhand I'd say that water is finding it's way in somewhere.
Old 03-08-2013, 01:23 PM   #4
There's rain water infiltrating that circuit somewhere... are there are visible signs of leaking at ceilings, windows or doors? Also, are their any outdoor receptacles or light fixtures attached to this circuit?
That fact that sometimes the GFCI won't reset immediately makes me think you have rain collecting in a junction box somewhere, probably one that is on a outside wall (possibly under a window).
Have you mapped out this circuit so you know exactly junction boxes are affected by the GFCI? I would start by shutting off this circuit, and then opening each junction box and inspecting for signs of recent water infiltration. Once you find, you'll need to fix the source of the leak.
clashley is offline   Reply With Quote
Old 03-08-2013, 08:21 PM   #5
Electrical Enthusiast
Rewards Points: 504
I would say you have an exterior outlet somewhere that you haven't found.
Either that or water is getting inside somehow....if this were the case you probably would have already noticed a leak.
Kyle_in_rure is offline   Reply With Quote
The Following User Says Thank You to Kyle_in_rure For This Useful Post:
oh'mike (03-09-2013)
Old 03-08-2013, 10:08 PM   #6
Rewards Points: 504
What's with all the spam posts lately?
Old 03-08-2013, 10:12 PM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
Sometimes they are worse than this.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 03-09-2013, 11:04 AM   #8
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
I agree with this post. Check all outside recepticles.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following User Says Thank You to electures For This Useful Post:
Wall damage below bathroom quaker87 Plumbing 8 02-28-2013 05:56 PM
Avoiding load on inner, exterior wall jklingel Building & Construction 2 06-04-2011 02:35 PM
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 09:22 AM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
