Wall Outlet Not Working - Electrical - DIY Chatroom Home Improvement Forum
Old 11-23-2008, 09:41 AM   #1
Angry
Wall outlet not working
Last night, in a fit of rage, my now ex-girlfriend knocked a lamp off my dresser. The lamp stayed plugged in when it hit the floor. It also still worked. She then proceeded to kick the lamp. The bulb didn't break, but the lamp and the outlet it was plugged into now no longer work. Does anyone know what may have happened electrically? I've checked my breakers and nothing has been tripped. Sorry for the extra personal type info, but it's the only way I could figure out how to word my question.
Bubby106 is offline   Reply With Quote
Old 11-23-2008, 11:26 AM   #2
Try the lamp in a different known-good outlet with a new bulb.
Try the girlfriend in a different outlet; it does wonders for Anger Management.
Nah, just kidding. The lamp should be way easier to fix than the girlfriend problem.
Old 11-23-2008, 12:35 PM   #3
Im thinking something shorted and burned a loose connection out...
rgsgww is offline   Reply With Quote
Old 11-23-2008, 02:09 PM   #4
joed's Avatar
Rewards Points: 13,740
The receptacle likely now needs to be replaced. It is probably physically broken inside.
Old 11-23-2008, 08:21 PM   #5
Agreed! And a word of advice, never say NO to a lady!
Old 11-24-2008, 01:50 PM   #6
Originally Posted by Bubby106 View Post
in a fit of rage
Once the outlet's fixed, you might look here
http://www.google.com/search?hl=en&q...+IV%22&aq=f&oq=
but don't tell her, or anybody else, what you've found. . .
Old 11-24-2008, 05:26 PM   #7
Talking
LOL. Well guess what? My wall outlet works now. Although none of the breakers tripped, I figured what the hell, I'll just turn each breaker off and then back on and see what happens. Lo and behold, that did the trick and now things are back to normal. Well at least as far as electrical outlets go...
Old 11-25-2008, 08:35 AM   #8
Rewards Points: 900
Actually, one of your breakers DID trip! When they trip, they don't move to the Off position, and often it's difficult to see which one has tripped.
Usually, you can tell by moving each one slightly towards off. The one that has tripped will be easier to move than the others.
What you did was to reset the tripped breaker.
Ultrarunner2017 is offline   Reply With Quote
Strange problem w. wall outlet, please help! yiplong Electrical 15 07-22-2008 04:02 AM
Converting wall outlet to power ceiling light? VEIK Electrical 3 07-08-2008 08:43 AM
Help Help richie02 Electrical 7 06-17-2008 08:42 AM
Low Retaining Wall cibula11 Landscaping & Lawn Care 3 07-29-2007 12:02 AM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
