Wall Mounting Tv, Want To Run The Wires Through The Wall - Electrical - DIY Chatroom Home Improvement Forum
Old 10-18-2012, 07:46 PM   #1
Rewards Points: 31
Wall mounting tv, want to run the wires through the wall
I want to wall mount my flat screen, need to figure out what to do with the power cable, cables to cable box, DVD player, etc.
- the best spot in my living room is on an exterior wall. Will I run into problems with insulation? House was built in 1940 and any insulation I've seen through other projects has been the blown in, dense, wool-like stuff.
-can I put a power cable in the wall or is that against code (or even worse, a fire hazard)
jmorc2003 is offline   Reply With Quote
Old 10-18-2012, 07:49 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
You can use a power cable in the wall to install a receptacle behind the TV. You can not use a cord in the wall.
Coastal South Carolina
Old 10-18-2012, 07:55 PM   #3
Rewards Points: 13,732
http://www.sjmediasystem.com/arl-tvb...n=bingshopping
Old 10-18-2012, 07:59 PM   #4
Rewards Points: 31
I'm trying to avoid a new outlet behind the mounted TV. That's more than I can handle and I'd rather not have to pay for an electrician.
I'm mounting the TV in the corner so what about a cord concealer running down the corner?
Old 10-18-2012, 08:15 PM   #5
Missouri Bound's Avatar
Probably the best idea. Wiremold is a company that manufactures this in various sizes and it's paintable.
Do you want it your way or the right way?
Old 10-18-2012, 09:09 PM   #6
Insatiable Learner
Rewards Points: 166
Smile
Originally Posted by joecaption View Post
Just used two of these and they work great. One for a widescreen and one for a air purifier. Installation was a snap and I highly recommend these
Monoprice carries these and they are very inexpensive. You mentioned your house was from the 1940's and you had used insulation. If your house has K&T wiring then just know that those two combinations are a fire hazard.
AngelArs is offline   Reply With Quote
Old 10-18-2012, 09:47 PM   #7
Semi-Pro Electro-Geek
Rewards Points: 2,938
Whenever I install a TV on a wall, I cut a hole behind it and mount a decora-style plate on the drywall, and then do the same down low (~12" above floor) where the AV equipment will sit. I just run the cables down through the wall and call it good. This could probably be considered a code violation with respect to the power cable, but there is an argument that it might not be. Regardless, that's what I do. You may find this extremely difficult to do in pre-war construction with old insulation.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 10-18-2012, 10:39 PM   #8
Insatiable Learner
Rewards Points: 166
Smile
Originally Posted by mpoulton View Post
I just run the cables down through the wall .
You might want to at least use a AFCI breaker on that circuit to give you some much needed protection.
Old 10-19-2012, 05:15 AM   #9
A "Handy Husband"
rjniles's Avatar
Where or who would think this is not a code violation?
Old 10-19-2012, 05:50 AM   #10
Rewards Points: 1,216
"That is a NO NO"
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 10-19-2012, 06:44 AM   #11
Rewards Points: 1,470
There is NO argument to be made at all. It most definitely IS a code violation.
If you are doing this on other peoples homes, I suppose you don't know that what you're doing is completely illegal, and could cause their homeowners insurance to not cover a loss.
I'd guess you're one of those who advertise on telephone poles or Craigslist and the like.
No insurance, no license, and no knowledge. Great combination...
ktkelly is offline   Reply With Quote
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 12:26 PM
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 06:23 PM
Wiring lights in new construction Mi Feller Electrical 38 06-10-2010 11:24 AM
Creating a hole in the wall to run wires, a good idea? RyanD General DIY Discussions 6 05-19-2009 03:30 PM
Mounting a TV "IN" a wall dchutnik Home Theater 3 01-25-2007 09:05 PM
