Wall-mounted Touch Switch Lamp Help - Electrical - DIY Chatroom Home Improvement Forum
Old 12-20-2006, 09:52 AM   #1
Wall-mounted touch switch lamp help
First post, so forgive me if I trespass or anything. My wife bought me a nice little swing-arm, wall-mounted, touch activated 3-way reading lamp. I mounted it on the wall and it works, but the "touch activated" part of it seems to be either very fussy or not work at all. Only specific places on the base (or arm) seem to activate it, apart from when it doesn't seem to activate it at all. Like now. Now I can't get it to activate at all. I've checked the bulb and the bulb is fine in other lamps. I think the problem is the touch activation. Any suggestions as to how to improve the sensitivity or workability of the touch activation? Would the fact that the mounting screws turned out not quite 100% flush to the wall? It's pretty close but not fully flush. Any help is greatly appreciated. Thanks! --Kevin
davros72 is offline   Reply With Quote
Old 12-24-2006, 01:13 PM   #2
Rewards Points: 79
Hello...and welcome! You aren't trespassing. Can't imagine what could be wrong. If you have the paperwork that came with the lamp, I would recommend calling the manufacturer for advice. Good Luck!
sootybuttercup is offline   Reply With Quote
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 09:44 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
ceiling fixture with on-off wall switch carlu Electrical 1 03-04-2005 08:13 AM
Wall Switch sue Electrical 4 02-06-2005 07:05 PM
