Wall Lighting Sconces - Electrical - DIY Chatroom Home Improvement Forum
Old 10-10-2010, 12:34 PM   #1
Wall lighting sconces
Can they be mounted on the wall for lighting without attic access and
controlled by a wall switch
Ricki525 is offline   Reply With Quote
Old 10-10-2010, 01:13 PM   #2
Licensed electrician
Rewards Points: 1,872
It is possible. It will depend on how much patching you want to do and where the power source is located.
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-20-2010 11:26 PM
Breaking up a long/continuous wall tigereye Interior Decorating 4 03-08-2009 03:43 PM
Loads on a partition wall acyate Building & Construction 8 02-28-2009 11:02 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
