Wall Light Vs Ceilin Cans - Electrical - DIY Chatroom Home Improvement Forum
Old 06-02-2011, 10:47 PM   #1
Rewards Points: 33
wall light vs ceilin cans
I am working on a home gym and the ceiling head room isn't what I'd ideally like it to be. Floor to bottom of joist is just under 8'. I do not want to go with a permanent drywall type of ceiling as I have piping and other cables run for the floor above. I'd like to do a drop ceiling, but I can't have it too far down from the joists. Just enough so I can drop in the tiles into the grid. That leaves me with limited options for ceiling lighting. I was thinking can lights that can go in between the joists which can help on space.
I was also pondering the idea of some wall lights or wall sconces. Maybe either that or can lights or a combination of both. Are there wall lights that would give off enough lighting for a home gym? The room is 21'x13'.
Any ideas or thoughts?
jgrohol is offline   Reply With Quote
Old 06-02-2011, 10:58 PM   #2
Licensed electrician
Rewards Points: 1,038
Fluorescent lights give off the most light for the least operating cost. I would consider a lay-in troffer or two.
Recessed would need to be mounted to the grid so the housing can drop down flush with the tile face.
Old 06-03-2011, 12:24 PM   #3
Rewards Points: 33
Would I be able to get the troffer light inbetween the joists?
wire two light sconces from one wall switch golfgirl Electrical 2 11-03-2010 07:32 PM
Replacing Bathroom Wall Mounted Light Fixtures Bob1946 Electrical 9 08-06-2010 02:28 PM
Wiring lights in new construction Mi Feller Electrical 38 06-10-2010 12:24 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
