Wall Heater Or Wiring Problems - Electrical - DIY Chatroom Home Improvement Forum
Old 12-28-2013, 09:43 PM   #1
Wall heater or wiring problems
Two small wall heaters in my basement suddenly stopped working. Electrical box fuses tested OK. When I used a tester to find the problem, found something that I can't understand, so I need help to fix it. The electrical box located in this basement receive two live wires from the house. Each have 120v to neutral and 240v between both. The two wires that go out of that box each have 120v to neutral but only 10v between both (instead of 240v) This is the part that I don't get it. I really appreciate an explanation before go further (tried two different testers with same results)
fredo55 is offline   Reply With Quote
Old 12-28-2013, 09:50 PM   #2
joed's Avatar
Rewards Points: 13,346
Is this just a junction box with cable in and out? If it is then it is a loose connection.
Old 12-28-2013, 09:53 PM   #3
Is a 60W electrical fuse box
Old 12-29-2013, 07:00 AM   #4
Rewards Points: 14,020
Hope that's Amp's not watts.
Old 12-29-2013, 07:06 AM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
It sounds as if you lost a leg and you are backfeeding thru a 240V load...range or the heaters. First thing to do is call the power company. If the POCO doesn't find anything on their end, it's time to call an electrician.
Old 12-29-2013, 07:56 AM   #6
An old Tradesmen
Rewards Points: 7,816
He said he does have 240 volt feeding the panel box. But doesn't have 240 volt coming out. Wouldn't that indicate the problem is with a breaker in that box, or the busses in that box. Not the service coming in.
The Following User Says Thank You to beenthere For This Useful Post:
k_buz (12-29-2013)
Old 12-29-2013, 08:05 AM   #7
k_buz's Avatar
Good catch, I got confused with his wording.
He has lost a leg...on the branch circuit. It's either a problem with his fuse box and the connections, or he does have a bad fuse.
I'm also a little skeptical about the overall wiring of the home. A typical 60A fuse panel will have only 1 spot for a 240V load. You will have a "Main" pullout and a (typically) "range" pullout. These two pullouts are sized for 35 to 60A cartridge fuses. A 30 or smaller fuse would require fuse adapters to be installed, and the only time I have seen them installed, are the times I've installed them.
Old 12-29-2013, 08:36 AM   #8
deverson's Avatar
Rewards Points: 77
If it's a 4 fuse panel there should be 2 screws between the first and second fuse and the third and forth fuse. Check for 240 volt there. May be a bad buss connection.
deverson is offline   Reply With Quote
Old 12-29-2013, 11:08 AM   #9
Thank you, it's amps
Old 12-29-2013, 11:09 AM   #10
This is a two fuse box
Old 12-29-2013, 11:57 AM   #11
deverson's Avatar
Rewards Points: 77
Are they cartridge fuses or screw in Edison base fuses? Post some pictures and we can all share in you fun and games!
Old 12-29-2013, 03:44 PM   #12
Here a picture
Volts in: 236
volts out: 10 red-black, 114 red-white, 119 black-white
This box was working well for the last 10 years.
Old 12-29-2013, 04:00 PM   #13
An old Tradesmen
Turn off power. Remove fuses, and ohm both of them out. Replace which ever one is blown. Look for short and repair.
Turn off power to the box. Remove all wires and put in wire connectors. then reconnect wires.
fredo55 (12-29-2013)
Old 12-29-2013, 04:03 PM   #14
deverson's Avatar
Rewards Points: 77
Turn off the feed to the panel. Go to the store and buy a new one. Preferably a circuit breaker panel with new circuit breaker. Also buy some 3/8" romex connectors. Remove the old panel throw in garbage can or recycle. Install new panel with romex connectors installed. That should take care of that problem.
The Following User Says Thank You to deverson For This Useful Post:
Old 12-29-2013, 04:19 PM   #15
I'll do what you guys suggested and will post next week. Thank you and happy 2014!
Need to attach B vent to wall heater Laneman HVAC 1 09-03-2012 05:34 PM
wiring fan, light, heater another light and GFCI Cvolpe Electrical 11 05-16-2012 07:13 PM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 09:18 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
