Wall Heater Disconnect - Electrical - DIY Chatroom Home Improvement Forum
Old 11-06-2011, 06:05 PM   #1
seansy59's Avatar
Rewards Points: 258
We have a small bedroom, and we have a few things in there we want to put in there, but we can't put them up against the walls with the 2 wall heaters.
We have a bed, desk, and tv unit, along with an in-wall closet. I have 2 heaters, one under a window, and one on a blank wall. Both are controlled by one thermostat. I'd like to disconnect the one up against the blank wall because I want to put a bed next to it, and can't because of the heater, as it is then a fire hazard.
Is it as easy as taking the heater wiring panel off, and capping the wires coming from the wall?
seansy59 is offline   Reply With Quote
Old 11-06-2011, 06:17 PM   #2
Licensed electrician
Rewards Points: 1,506
As long as the wiring remains accessible I don't see an electrical issue with capping the wiring.
The issue may be that you will not have enough heat in the room with the one removed.
seansy59 (11-06-2011)
Old 11-06-2011, 06:35 PM   #3
seansy59's Avatar
Rewards Points: 258
It was just the electrical issue that I was worried about. The room is actully warm even with the heat off most time, and I used to run a small oil radiator on low every now and then, and that would still toast it up, so I should be fine now with an even bigger and higher wattage wall heater.
Thanks!
Electric Wall Heater Shield JTee Electrical 1 02-13-2011 12:35 AM
wall heater or baseboard? debiasio HVAC 1 02-08-2011 10:54 AM
ceiling fan above wall heater photomikey HVAC 0 11-23-2010 04:09 PM
Correct gauge wire on wall heater?? Master Brian Electrical 4 11-16-2010 01:48 PM
Cadet wall heater Jack E HVAC 1 04-21-2010 04:55 PM
