Wall Heater Connection To Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 06-18-2008, 10:02 AM   #1
Question
Wall heater connection to breaker
I want to wire a small 240-volt 1500 watt wall heater in bath. Instruction says connect the red and black wire from heater to incoming power white and black - no polarity required. Ground wire attaches to grounding screw on box. That part I get. However there is no mention regarding connection to the breaker box. Am I correct in assuming I wire this as you would a normal outlet (black to single pole 20amp breaker and white & neutral to box nuetral bar) or am I missing something?
mw6263 is offline   Reply With Quote
Old 06-18-2008, 11:36 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 252
No! You must install a 20 amp 2 pole breaker. Connect the black wire to one side and the white wire to the other side of the breaker. Remark the white with a peice of red or black tape. Connect the ground wire to the ground bar.
Old 06-22-2008, 11:47 AM   #3
Thanks jbfan
Thanks. You saved me a mess.
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Heater causes breaker to hum oakwood02 Electrical 3 01-03-2008 07:50 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Hole in wall w/ stress cracks... lots of detailed pics (NOT 56k connection friendly) Thaipo Building & Construction 8 05-21-2007 07:40 AM
How to Space Water Heater Flue Vent from Outside Wall? austinbirdman Plumbing 1 03-12-2007 11:28 AM
