In-wall Digital Timer Installation - Electrical - DIY Chatroom Home Improvement Forum
Old 08-02-2010, 09:41 AM   #1
Hi there- My front entrance-way has an old timer and a light switch in the box. The timer controls 2 lights, one over the front door and another over the garage door... while the switch controls the inside light. This inside light is also controlled by another switch (if that matters).
Anyway, the older timer had two black wires attached to it, one coming from the wall and the other coming off the switch. However, my new timer has a black, white, red and green wire. I linked the white to a group of neutral white wires tucked into the back of the box, attached the black to the hot black wire coming from the switch, attached the red to the other black wire coming from the wall and grounded the green.
All works well for the front door light, but the garage door light is no longer working??? Any advice for me? Thanks!
worked is offline   Reply With Quote
Old 08-02-2010, 09:55 AM   #2
Just call me Andrew
Rewards Points: 1,020
What is the make/model of the new timer?
It sounds like the new timer needs a neutral wire attached to it, whereas your old one did not.
Are the bulbs in your garage lights fluorescent?
Andrew
secutanudu is offline   Reply With Quote
Old 08-02-2010, 10:23 AM   #3
Utilitech In Wall Digital Timer
Yes, it did need to be attached to the neutral wire, unlike the old one.
No, the bulbs are not fluorescent.
I'm thinking it's the timer... the wiring seems right to me. Any other advice is appreciated!
Old 08-02-2010, 10:42 AM   #4
" Euro " electrician
frenchelectrican's Avatar
When you hook up the timer for the outside luminiares did you noted there were just one conductor going to the luminaire or there were two conductors if that the case double check the wirenuts sometime they not always be on right spot so double check if that comeout good.
Then you will have to check the outdoor luminaire nearest the switch to see if the connection is clean and tight.
Merci.
Marc
Tags
timer
Drain tile questions for retaining wall installation. Tmaxx1 Landscaping & Lawn Care 11 06-10-2011 12:17 PM
Help installing wall switch light timer Aube TI071 Rachey Electrical 10 12-24-2010 12:02 PM
Leviton timer installation - ok with whole house fan? feign3 Electrical 8 03-16-2010 06:16 PM
Intermatic Digital In-Wall Timer ST01C themayor Electrical 9 03-02-2009 06:14 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
