Purchased a new Electrolux double wall oven -240v-for my kitchen remodeling.
I"ve run a new 6-3 line to the location where the new ovens will be.
I'm not sure what would be the 'correct' way to make the connections
as far as the box and covering it goes.
I have an 'old construction' plastic double gang /deep box I was planning on using, but they are big wires and I"m not sure they are going to fit in their easily.
Is there a 'special' wall box to use for this type of application?
Secondly, the new ovens have an armored cable.
Is there a proper way to makes this connection to the box.
My old oven (put in by the original contractor), was just left open and the connections made and the wires stuffed inside it. THen left that way(for 30 years
I'm thinking there must be some type of a 'blank' with a knockout in the middle that I need for this yet to be determined 'large' wall box I should have?
Or, is how it was done the first time proper? Just hook em up bl-bl, rd-rd-wh-wh and grd-grd and stuff em all inside this box and just leave it (common sense tells me NO )
Thx in advance
