Wall Box For Bathroom Vanity Light - Electrical - DIY Chatroom Home Improvement Forum
Old 07-06-2012, 10:28 AM   #1
Wall box for bathroom vanity light
I am trying to replace the ugly chrome fixtures in my master bath
with something similar to this:
There is no box in the wall behind the existing light, just a hole in the sheetrock that they pulled the wires through and hooked up. There is a big support bracket that is screwed to the wall with drywall anchors. One of the boxes is centered directly over a stud, so I installed a 1/2" pancake box mounted directly to the stud. The other box will fall between studs. I'd rather not use one of these romex old work round wall boxes, since they don't appear to be able to support more that 6 lbs (the new fixture is right at 6 lbs). I don't think one of the smart boxes will work either, the box will be too far away from either stud.
Can one of these ceiling boxes with the adjustable bar hanger in a wall? I've looked at the spec sheets for the steel city and the arlington hangars, but neither mention use in a wall. This is the type of box I am referring to:
or
woodardhsd is offline   Reply With Quote
Old 07-06-2012, 05:55 PM   #2
DIY staff
Rewards Points: 7,174
That box in the lower picture will do the job---good choice--
Old 07-06-2012, 06:40 PM   #3
Rewards Points: 12,794
One of these would be simpler to install and you would have to make such a big hole in the wall.
http://www.homedepot.com/buy/electri...ars-48609.html
PaliBob (07-06-2012)
Old 07-10-2012, 11:54 AM   #4
That would be easier, but can that box support a 7lb fixture?
Old 07-10-2012, 12:23 PM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You don't need something as beefy as what is pictured in the OP. those are rated for ceiling fans. They make round plastic boxes with a simple brace that would do the job at 1/10th the cost. (if the wiring is something other than romex, the also make metal boxes with braces that are much cheaper as well.)
Old 07-10-2012, 12:33 PM   #6
I like your ugly chrome fixture.
CopperClad is offline   Reply With Quote
Old 07-10-2012, 01:38 PM   #7
I got 3 of them, make an offer
Seriously though, it's half the looks, half the halogen bulb that they use. They are approximately the same brightness and temperature of the sun.
Old 07-10-2012, 02:13 PM   #8
k_buz's Avatar
I slimmed thru your first post an. Didn't realize the drywall is up. They make a round plastic cut in box specifically for mounting fixtures.
Old 07-10-2012, 05:53 PM   #9
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
You need to buy old work boxes...
How to Customize Thin Wall Cabinet with Light cjakins Electrical 0 11-15-2011 09:24 PM
Installing bathroom wall light C.Jones Electrical 1 09-11-2011 01:03 PM
Electrical bathroom vanity light fixture HEMMY1244 Electrical 4 09-29-2010 08:40 PM
bathroom remodel at a stand still becuase of floating vanity installation diy'er on LI Kitchen & Bath Remodeling 10 11-23-2009 02:12 PM
vanity light wiring hsw55 Electrical 5 03-28-2009 08:47 PM
