Wall Anchors - Electrical - DIY Chatroom Home Improvement Forum
Old 11-14-2006, 10:43 AM   #1
Wall Anchors
What size wall anchors should I use to mount my 12 breaker sub panel to the concrete block wall in my basement. I was thinking of using the hammer set anchors. They seem to only come in 1/4 diameter. I am not sure what lenght to use.
Gus
ffgus is offline   Reply With Quote
Old 11-14-2006, 03:51 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,864
I would mount a piece of plywood to the block and then mount the panel to the wood.
You can use concrete nails, a ramset tool, Tapcons, etc, to mount the wood.
Old 11-14-2006, 05:21 PM   #3
World famous jerk.
For mounting a panel on concrete or block, I do as Speedy says. Actually, I alternate between plywood and using #12 plastic anchors with #12 x 2" hex washer head screws. Using that method, I use a spacer at each screw location made from a piece of 1/2" pvc conduit cut to 1/2 or 3/4 of an inch. DO NOT mount your panel directly on the concrete without some plywood or a spacer of some sort. Your panel will rust, guaranteed.
mdshunk is offline   Reply With Quote
Old 10-17-2011, 12:16 PM   #4
Code05's Avatar
Rewards Points: 1,104
Originally Posted by margarette29 View Post
for best wall anchors! try this for yourself --> REMOVED
margarette, welcome here.
This thread is 5 years old and the topic was concrete mounting anchors, not foundation repair.
Code05 is offline   Reply With Quote
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 04:49 PM
Suggestions for wall anchors MIKEGOUGH1 Building & Construction 1 12-06-2006 10:23 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
