In Wall AC/Heater What To Buy? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-20-2010, 02:53 PM   #1
In wall AC/Heater what to buy?
I live in an older home which has an in wall AC unit that needs to be replaced. I want to replace it with a unit that also provides heat. Before I purchace a new unit, I want to make sure I have the correct power available.
I have attached pictures of the existing unit, the plug and the breaker box.
Please let me know what would be acceptable.
What is the maximum size unit, and what is the minimum size that would work, power wise.
The space I am trying to heat/cool is ~350 sq ft.
Thanks for your help.
In wall AC/Heater what to buy?-plug_.jpg   In wall AC/Heater what to buy?-unit_.jpg   In wall AC/Heater what to buy?-breaker_.jpg
Furuoka is offline   Reply With Quote
Old 11-20-2010, 04:10 PM   #2
Craftsman
You have a 20 amp 230 volt receptacle with a 30 amp breaker feeding it. You really need to find out what size wire is feeding the circuit. Then you can look for a unit. I recommend the zoneline units to many customers. These are the one you see in many motels. They make a resistance heat unit with AC and a reverse cycle heat pump unit. The resistance unit heats a room quickly but draws more power when heating (if you don't use the room often and want a quick warm up) and the heat pump uses less power but may take about hours to stabilize room temperature when left off. Hope this helps!
Superrick is offline   Reply With Quote
Old 11-20-2010, 04:18 PM   #3
Rewards Points: 150
Now do they have a model that's normally reverse-cycle but has aux resistance heat?
emolatur is offline   Reply With Quote
Old 11-22-2010, 03:33 PM   #4
I dont know if anyone will be able to tell from the pictures but I took the box apart and took some photos of the wiring to try to get an idea of the size of wiring.
This is the unit I am thinking of getting.
http://www.ajmadison.com/cgi-bin/ajmadison/KC35HA.html
In wall AC/Heater what to buy?-box-wiring-1.jpg   In wall AC/Heater what to buy?-box-wiring-2.jpg   In wall AC/Heater what to buy?-box-wiring-3.jpg
Old 11-22-2010, 03:34 PM   #5
FYI the screw that I used as a gauge is the screw from the plug.
Cutting through masonry wall mwpiper Remodeling 4 04-17-2010 10:30 AM
building a wall against an exterior wall Mike L General DIY Discussions 2 08-20-2009 02:50 PM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 03:29 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
