#1 |
Walk-in closet switch location
If you've got a walk-in closet that's about as big as your average bathroom, (5'X8') why can't the switch be located inside the closet (at the door)? What if you've got a really large walk-in closet with a desk, make-up mirror, and want to add an outlet for a blow dryer? Does it then become a "dressing room," instead of a closet? Just wondering...
#2 |
Electrical Contractor
We install a sensor in the door and a Remcon unit for automatic operation.
Works the same as your fridge: open the door, light comes on!
#3 |
Walk-in closet switch location |
#4 |
Bubbagump, Took a hit on it during an inspection (here on Long Island, NY). I figured that if the luminaire aspect was good, a switch should be no problem. That's what I get for thinking....
#5 | |
Electrician
Walk-in closet switch locationQuote:
Put the switch anywhere you want, and ask for the actual violation and get back to us.
#6 |
You lost me. What did you get dinged on specifically in the inspection?
The reason I ask is that there is no screwier batch of codes than in NYC or California. So I am wondering if there is something local that you have to worry about that I have no knowlege of. |
#7 |
Moderator
Agreed, NY may have some screwy addition to the code. But, based on the IRC and the NEC, there's no violation in putting it in the closet.
#8 |
What type of place could I find this switch? We're considering installing one/having one installed in our pantry. Is it also called a door jamb switch? When searching the Internet, all I find are switches for vehicles. I just got back from Lowe's and they don't carry them. Is it something simple to install?
#9 | |
Licensed Electrical Cont.
Jeeze, things have gotten bad since I moved from there.
Sometimes I feel like if I answer any more questions it is like someone trying to climb over a fence to jump off a bridge and me giving them a boost. |
#10 | |
Go back to message #2 in this thread, and click the link.
It operates with an external switch. You can use magnetic contacts embedded in the door and the jamb, or surface mounted on the outside of the door. Or you can always use the bulky "door jamb" switch, but those are more labor intensive to install. |
#11 |
This is a job that I started in 2005 for a neighbor. She bought and gutted the house with plans of renovating it. I did the service (completely inspected) and had the rough inspection done with no problems. Money ran tight and I had to go to the desert for several months (which turned into 22 months). They had to file for the inspections themselves and this was one of the things the new inspector turned up. One violation: "This is something your electrician should've known. It's been on the books since day one. No switches inside a walk-in closet." Hmmm.
#12 | |
#13 |
I was thinking things more colorful.
#14 |
I found another idea on-line. Instead of doing all this electrical work to get light in a closet/pantry, they just simply put a motion sensor lightbulb in there. That sounds like an easy solution.
#15 |
electrician
Your inspector is an idiot. Tell him he's an idiot. Call his boss (everybody has one) and tell him that he's an idiot. If enough people call his boss, you won't have to deal with him anymore.
We had the same problem here, the guy was gone within 6 months, contractors just have to stick together. |
| Display Modes | |
| 3-Way Switch Wiring | MrBill_DIY | Electrical | 8 | 09-07-2008 06:53 PM |
| Closet Light and switch | Skydmark1 | Electrical | 2 | 12-10-2007 11:53 AM |
| Light switch location | ADKstorm | Electrical | 4 | 09-10-2007 07:41 AM |
| Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) | inspectator | Electrical | 8 | 08-07-2007 02:19 AM |
| Detached garage adding a 3 way switch. | Slatherd | Electrical | 4 | 01-02-2006 03:53 PM |
