Wadsworth 100 Amp Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 01-02-2012, 09:35 PM   #1
I have an old 200 Amp Wadsworth service panel and I want to have a new 100 Amp sub panel installed in my home. I would like to feed the sub panel with a 100 Amp circuit from the Wadsworth panel. So, I need to purchase a 100 Amp Wadsworth breaker. I have seen plenty of these for sale on online auctions but they seem to have been main breakers.
I have two questions. First, I'm wondering if Wadsworth made different lines of service panels, or will any Wadsworth breaker fit my panel. Second, I'm wondering if a main Wadsworth breaker can be used on the lower part of the panel as a regular circuit breaker.
Thanks in advance.
jheathma is offline   Reply With Quote
Old 01-03-2012, 01:42 AM   #2
jproffer's Avatar
Rewards Points: 712
Don't know about Wadsworth, in particular, but I'll help ya bump this up a little ....and give some general info/observations.
I've never seen a main breaker, for ANY brand panel, that will fit or work in the secondary part of the panel.
I would say as long as the neutral and grounding bars can be seperated, any panel can be made into a sub-panel.
You will need 4 seperate conductors to feed your sub-panel, since...as implied above, your neutral and grounding bar have to be seperated in the sub.
jproffer is offline   Reply With Quote
The Following User Says Thank You to jproffer For This Useful Post:
jheathma (01-05-2012)
Old 01-03-2012, 01:52 AM   #3
" Euro " electrician
frenchelectrican's Avatar
There are few differernt verison of Wadsworth breaker on market but IMO I am not too crazy to mess around them due they are old on agewise.
Thanks in advance.
Unforetally if you have split buss panel then no it will not fit due there are few limitations it will show up one is the split buss breaker for lower section is limited from factory so you can not able change the rating at all.
Second thing if you can able read the label inside the panel door that will tell you the type of breaker you can use otherwise post the photo one of us will indentify it for you.
For the last resort I know you may not like hear this but it will be a good time to upgrade to modern panel for few good reason one is you have common breaker so you will not have to look hard to find oddball one.
Second thing I know Wadsworth breaker never have AFCI or GFCI breaker at all so that is the other reason.
The new 200 amp panel will fit roughly the same size as your old 200 amp panel is but you will have more circuit in there.
This typically useally done by electrician due there are some codes may prevent the homeowner to do this but I know few homeowners can able change the panel themself but check with the building inspectors due the answers will varies a bit.
Costwise that part I can not really comment due there is too many variation to determed a excat price range will be at.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
Old 01-03-2012, 02:10 AM   #4
Rewards Points: 1,192
New Year,New Panel.
bobelectric is offline   Reply With Quote
Old 01-03-2012, 07:29 AM   #5
Rewards Points: 760
how far will be your sub panel form your mail panel, if it is very close you wont need a breaker in main panel, check on NEC for double tap rules
carmusic is offline   Reply With Quote
Old 01-03-2012, 10:30 AM   #6
Thanks for the replies.
I would love to have a new SqaureD Quo panel installed to replace this old Wadsworth but it is around $800 to have an electrician do it (I don't think that I want to DIY for fear of dying). I might end up having to replace the panel but I would like to at least investigate the less expensive route.
The number on the panel is L200MB20-40.
Here is a picture of it. I can take a picture with the cover off but I'll have to wait until my wife comes home because I would prefer someone else to be around when I remove the cover. (I don't like this panel)
If anyone knows where I could find a breaker that is large enough to feed a sub panel then that would be awesome.
Wadsworth 100 Amp Breaker-img_2032.jpg   Wadsworth 100 Amp Breaker-img_2031.jpg
Old 01-03-2012, 10:33 AM   #7
carmusic, Thanks for the tip but my subpanel will be about 20 feet away which will require a disconnect.
Old 01-03-2012, 12:55 PM   #8
Licensed Pro
Just an observation, but if all those circuits in the existing panel are in use, there is no room for an additional breaker to power a subpanel.
Old 01-03-2012, 01:27 PM   #9
Licensed electrician
Rewards Points: 1,618
A panel in the same building as the one it is fed from does not require a main breaker.
Old 01-03-2012, 02:06 PM   #10
Househelper -- The sub panel will be able to take on a few of those circuits so there will be some free spaces.
Old 01-03-2012, 02:31 PM   #11
Licensed Pro
Got it. Check out some of the online suppliers like Pacific Coast or Bay Breakers.
Old 01-03-2012, 02:42 PM   #12
Try Ebay, I needed an obsolete breaker and purchased a new one on line from a seller on Ebay. Pricey but less then half the price from the local electrical supply house.
Hardway is offline   Reply With Quote
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Replacing and Moving a Fuse box with a breaker box nightrook Electrical 18 09-24-2009 07:49 PM
I can "double" the wires to each breaker in my breaker panel right? Piedmont Electrical 40 10-01-2008 11:18 AM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
