Voltages - Electrical - DIY Chatroom Home Improvement Forum
Old 02-26-2013, 02:49 PM   #1
Voltages
Can transformers be operated at voltages other than nameplate voltages?
e3belectrical is offline   Reply With Quote
Old 02-26-2013, 05:03 PM   #2
Rewards Points: 14,312
Sure they just not going to last for long.
Old 02-26-2013, 07:10 PM   #3
Electrical Contractor
kbsparky's Avatar
Yes, if the applied voltage is less than the rated value. I have used a 240x24 volt transformer to obtain 12 volts using a 120 Volt supply. But be warned: The Amps rating is the same, but your output watts will be considerably less than the original rating.
If you apply a higher than rated voltage to the unit, it may operate for a time, but premature winding burnout may be a consequence.
-KB
weird wiring and wierd voltages on 3 dual switches... meweber1000 Electrical 5 12-18-2012 12:37 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 09:13 PM
Weird Voltages matt151617 Electrical 8 07-06-2011 08:23 AM
AC Voltages on the Neutral/Ground smata67 Electrical 9 06-01-2011 08:09 AM
Carrier Weather Maker inducer voltages used2beatech HVAC 16 10-16-2009 02:43 AM
