Voltage Too High For Light Sockets - Electrical - DIY Chatroom Home Improvement Forum
Old 07-12-2013, 03:40 AM   #1
Voltage too high for light sockets
I removed a non-load-bearing wall and all went well. Next I needed to relocate the light switches. All 3 switches were on dimmers and operating correctly. I rewired everything, but now face the problem that only 1 of my 3 lights is working properly. Two of them appear like they are getting too much voltage. They are WAY brighter than they were before and when I move the dimmer setting all the way down, the brightness is cut in half, but still quite bright.
When I tie the switch directly to the light wiring, it does not have any power and the switch does not work. Leaving one wire tied to the switch and the second wire spliced to a hot wire and a wire from the switch is what is causing it to be a super high voltage. I have also tried switching which of the two wires is connected to hot and directly to the switch. There is no difference. Both situations lead to a bulb dangerously bright and a dimmer that only dims halfway at best.
Any suggestions what I might have done wrong?
Thank you.
-Steven Wolff
swolff is offline   Reply With Quote
Old 07-12-2013, 07:17 AM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Thank you.
-Steven Wolff
take some pics on what you did....
Old 07-12-2013, 07:21 AM   #3
DIY staff
Rewards Points: 7,174
You have a multi wire branch circuit with a missing neutral---this is bad.
I'll leave this for an electrician to answer----you need a two wire tester to find the two different 110 lines (each from different legs) and fix the missing neutral---
This condition will ruin ant electronics--so fix it quickly nefor you fry a computer,t.v. or fridge--Mike---
Old 07-12-2013, 07:23 AM   #4
DIY staff
Stick boy is an electrician! You will get your answers now---Mike---
Old 07-12-2013, 06:29 PM   #5
dmxtothemax's Avatar
Rewards Points: 5,096
You have lost your neutral !
This is a dangerous situation !
Is everything else in the house ok ?
Dissconnect everything you have done !
post a pic of all the wiring spots,
clearly showing all wires and there colors !
dmxtothemax is offline   Reply With Quote
Old 07-13-2013, 12:59 AM   #6
" Euro " electrician
frenchelectrican's Avatar
Either you have two circuits in that switch box or have MWBC mixed up that the two most common cuprit.
Do you have three way switches in that location ?
How many power sources in that switch box ? ( the answer will tell you if you turn off one or duex breakers if two then you have two circuits. )
Merci,
Marc
Old 07-13-2013, 01:14 AM   #7
Rewards Points: 6,652
Either pushing 240vAC through the bulbs, or lost the Neutral. They will only handle 240VAC for so long, before they either melt the sockets from the heat, the glue becomes so solvent that the bulbs fall out of the metal Edison bases, or you see the Magic Smoke or Fire shooting out of the light fixtures.
Old 07-13-2013, 09:28 AM   #8
Rewards Points: 150
actually the element will burn out and the bulb will no longer work.
RIP EJT
usair is offline   Reply With Quote
Old 07-13-2013, 10:23 AM   #9
Electrical Enthusiast
Rewards Points: 504
I'll second the above.
You have a MWBC (multi-wire branch circuit) (two hots, a neutral, and a ground) that has been miswired. You need to check everything you've done, and you need to disconnect ANY appliances connected on these circuits.
Kyle_in_rure is offline   Reply With Quote
The Following User Says Thank You to Kyle_in_rure For This Useful Post:
oh'mike (07-14-2013)
Tags
high voltage , voltage
Can someone tell me why my low voltage lights are reading high current at the switch? kmc Electrical 5 06-04-2012 10:38 PM
Flickering lights on circuit with low voltage and line voltage bulbs davidwiesel Electrical 4 04-18-2011 09:54 AM
Voltage in Metal Roof and Gutters TITAN2390 Electrical 4 10-07-2010 08:44 PM
High Voltage Test ?? Melanie337 Electrical 20 10-20-2009 03:19 PM
Low voltage in same box as high voltage? mpedrummer Electrical 2 02-28-2007 12:49 PM
