Voltage Testing Question...... - Electrical - DIY Chatroom Home Improvement Forum
Old 10-03-2011, 11:54 PM   #1
voltage testing question......
I've installed a 220 1 phase 50 amp breaker for a small welder, can I test power by using a Klein ET50 tester and plugging it into both hots?
I used #6 wire and its located 2' from the panel.
Thanks....
serrano is offline   Reply With Quote
Old 10-04-2011, 12:27 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 790
Why not use a regular voltmeter and just measure from hot to hot....should have have 'around' 240 Vac. And if you measure from either hot to ground...around 120 Vac.
ddawg16 is online now   Reply With Quote
Old 10-04-2011, 04:44 AM   #3
Code05's Avatar
Rewards Points: 1,104
The Klein ET50 is a voltmeter.
http://www.homedepot.com/buy/electri...er-165789.html
Code05 is offline   Reply With Quote
Old 10-04-2011, 04:46 AM   #4
Code05's Avatar
Thanks....
Yes you can.
Old 10-04-2011, 03:29 PM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 790
Originally Posted by Code05 View Post
I don't call that a voltmeter....I call it a "You might be in the ballpark" indicator....
My Fluke 179 is a voltmeter....my Simpson 260 is a voltmeter....that thing is not a voltmeter....there is no meter on it......
Old 10-04-2011, 04:50 PM   #6
Missouri Bound's Avatar
Didn't you read the description?......."designed by electricians"
Old 10-04-2011, 04:54 PM   #7
I=E/R
a7ecorsair's Avatar
You missed the best part
This tester was designed by electricians, for electricians
a7ecorsair is offline   Reply With Quote
Old 10-04-2011, 09:45 PM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 790
Oh....well....in that case, I stand corrected....guess I'll have to throw away all my meters.....I have 4 of them...
Old 10-05-2011, 05:53 AM   #9
Code05's Avatar
Yeah yeah ....I know it is not the best, but it is better than a Radio Shack special.
Few DIYers will even buy any testers at all. Most have a NCVT pen at best.
The ET-50 is only $21.00, so you cannot expect much.
I recommend the T5-600 to most people.
Flickering lights on circuit with low voltage and line voltage bulbs davidwiesel Electrical 4 04-18-2011 09:54 AM
Backflow device testing - possible scam? ScottR Plumbing 9 06-14-2009 11:55 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Low voltage box question WShawn Electrical 7 08-19-2008 07:22 AM
Low voltage wire entering/exiting walls need box? Azeiku Electrical 2 07-07-2008 05:55 PM
